Garlic Bread
Gaz6002
Right, here's a weird one.
I'm cooking some pasta tonight and as part of the meal I want to do some garlic bread. I can't decide on the best way to cook it though so what is your favourite method?
I know it's random - I don't care.
I know this isn't a cookery forum.
I know I'll get some stupid answers.
I did search and nothing came up.
  • Replies 64
How much garlic do you like?
Could be a simple butter and then baked until crisp or a wipe of a garlic clove over the bread of choice before grilling.
Personally I don't like dry bread so a nice garlic butter generally works best IMO but then it's far easier to just buy one and stick it in the oven.
I saw in Asda once that Lurpack did a Garlic butter, if they still not that just buy a tub, warm your french stick up and bob's your uncle ;)
I'm not a fan of dry bread either to be honest - would you use something like ciabatta? I think I'd like it on a pizza base but I'm not sure it will work out too well...
Hmmm I'm more inclined to make things from scratch if I can, that way I can feel like I could live in a world without labour saving devices... whatever the truth really is :D
I would take a fresh baguette or ciabatta to start with, then I would chop several cloves of garlic very fine with some salt, add fresh chopped parsley, black pepper and a little lemon zest,then mix with softened unsalted butter, cut the bread almost all the way through from top to bottom all the way along the length, 1 inch or so apart, stuff with the garlic butter and close the gap up again
Bake in a hot oven until golden, very nice :D
You could make a very thin pizza base with bread dough bake this in a hot oven, just before it is ready brush with plenty of good olive oil and chopped garlic mixed with chopped fresh oregano and back in the oven until golden, very nice :D
See now I'm liking this idea... hmmm that sounds almost perfect for my meal...
Me thinks you've done this before...
Personally, I like it strong :D
So... butter and lots of finely chopped garlic into a bowl, microwave for 10 seconds and mix well. Add parsley for a little extra taste... Then spread then use a spoon and spread/pour onto bread, this gets a bit messy!
If you dont like it strong, do it like bruschetta (sp?)... Toast bread, then rub with garlic, then butter while still warm/hot!
Now I am hungry, thanks :(
Buy a big french loaf, buy some garlic butter, slice the loaf till it almost breaks off (leave a few mm at the bottom), heat the butter a little so that its spreadable, spread garlic butter on slices of bread (still without breaking), put in oven at 180 degrees C for about 10 mins then serve.
Job done. Will take a lot of garlic butter though, 1 little tub per 2 slices minimum.
See? That's why I love this forum. I can go to Sainsbury's at lunch and buy all my stuff now without worrying about the best way to make it = more time in the wine section. Result :D
All the suggestions sound lovely. Very hungry now!
If you want wine advice, you only have to ask :)
I like the rubbing garlic on technique. Although I like the moisture of butter added too.
I'm hungry now!
this does give a very subtle finish, this method I slice the bread, drizzle with oilve oil (scented with herbs), bake until crisp in the oven then rub with a cut garlic clove and 1/2 a tomato also rubbed on the bread to add a little moisture
