Nic Posted August 11, 2008 Share Posted August 11, 2008 I have a customer who needs a right hand side ignition dash panel for a UK spec Supra. Unfortunately these have been discontinued and Toyota no longer have stock. I am not as familiar with the UK Spec Supra so need some clarification if anyone can help. I believe all the UK spec Supras have 3 holes in the ignition panel for the 3 buttons as shown here, correct? I can supply pre-facelift J-spec ignition dash panels, which are basically the same, but AFAIK these are only available with a single hole. Is there anyone with a pre-facelift J-spec Supra that has more than one hole in the ignition panel? If you do, would you mind sending me your frame and model number so I can check the part number. http://img215.imageshack.us/img215/7140/trdwheel7eq.jpg Link to comment Share on other sites More sharing options...
Nic Posted August 11, 2008 Author Share Posted August 11, 2008 I have a customer who needs a right hand side ignition dash panel for a UK spec Supra. Unfortunately these have been discontinued and Toyota no longer have stock. I am not as familiar with the UK Spec Supra so need some clarification if anyone can help. I believe all the UK spec Supras have 3 holes in the ignition panel for the 3 buttons as shown here, correct? I can supply pre-facelift J-spec ignition dash panels, which are basically the same, but AFAIK these are only available with a single hole. Is there anyone with a pre-facelift J-spec Supra that has more than one hole in the ignition panel? If you do, would you mind sending me your frame and model number so I can check the part number. http://img215.imageshack.us/img215/7140/trdwheel7eq.jpg Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 11, 2008 Share Posted August 11, 2008 I have one of these UK spec 3 hole panels in my garage spare Link to comment Share on other sites More sharing options...
Nic Posted August 11, 2008 Author Share Posted August 11, 2008 I have one of these UK spec 3 hole panels in my garage spare Thanks Dean, is it in good condition? It is just I have supplied new panels for the rest of the dash and so the ignition panel will need to be in good condition so it will match. Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 11, 2008 Share Posted August 11, 2008 Thanks Dean, is it in good condition? It is just I have supplied new panels for the rest of the dash and so the ignition panel will need to be in good condition so it will match. Nic It has had a 'stick on' carbon dash at some point so it would need some work, may look out of place with a new set of panels Link to comment Share on other sites More sharing options...
SteveR Posted August 11, 2008 Share Posted August 11, 2008 I think there are a few more UK/J-Spec dash panel differences, Nic. Let me go seaarch for the thread I have in mind.. EDIT here we go, posts 3 & 4 are of note: http://www.mkivsupra.net/vbb/showthread.php?t=157200 Link to comment Share on other sites More sharing options...
