LIKWIDART Posted August 10, 2008 Share Posted August 10, 2008 My rads just blown on my 1994 Twin Turbo Supra, split at the top. Does anyone know if I should fit an original Toyota radiator or is there a better alternative replacement? - any suggestions appreciated. Regards - Rob - Likwidart. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 10, 2008 Share Posted August 10, 2008 I have new stock TT rads in stock. Were you using a chromed radiator top pipe? These are known to put excessive loadings into the rad with the consequences you have found. the stock rad has a VERY efficient and modern core, the aluminium aftermarket ones are rarely any better. Unless you have a specific need for an alloy rad I'd stay stock. Link to comment Share on other sites More sharing options...
SteveR Posted August 10, 2008 Share Posted August 10, 2008 Just don't run with a TRD rad cap, whatever you do. Link to comment Share on other sites More sharing options...
Ian Ian Posted August 10, 2008 Share Posted August 10, 2008 Like chris says stick to the Toyota rad Rob easy peezy to replace etc etc Cheers -Ian- Link to comment Share on other sites More sharing options...
LIKWIDART Posted August 10, 2008 Author Share Posted August 10, 2008 Hi Chris. I don't have a chromed top pipe but have the original rubber. The car started ticking over at 500rpm rather than 800, and the a split occured at the top of the rad just below and to the side of the rad cap. What am I looking at for a new rad from you Chris. Can't move the car until a new one's fitted. Regards - Rob - Likwidart. Link to comment Share on other sites More sharing options...
LIKWIDART Posted August 10, 2008 Author Share Posted August 10, 2008 Thanks for the info guys - I'll stick with a new original Toyota rad if I can get one. Regards - Rob - Likwidart. Link to comment Share on other sites More sharing options...
