Faye Brother Posted August 10, 2008 Share Posted August 10, 2008 I'm fairly sure this harness will allow the easier wiring up a piggyback ECU, an E-Manage, for example, but I would be grateful if some could confirm that for me so I don't give a potential purchaser the wrong information. Also, does anyone have an idea what the white plug on the end of the long black wire would connect into? The plug has two rows of eight holes, but there are only wired pins in twelve of the holes. Quote Link to comment Share on other sites More sharing options...
Ric Posted August 10, 2008 Share Posted August 10, 2008 yes & the white plug on the end would clip into the device you have just wired in, gauge, fcd, ecu, whatever Quote Link to comment Share on other sites More sharing options...
Faye Brother Posted August 10, 2008 Author Share Posted August 10, 2008 Thanks, Ric. Much appreciated. Quote Link to comment Share on other sites More sharing options...
Guest SupraBoy_BG Posted August 25, 2008 Share Posted August 25, 2008 Can someone confirm that this harness will clip into e manage blue models,and also is there better pictures of the white clip that supposed to clip to the ecu,device ect...thanks Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 25, 2008 Share Posted August 25, 2008 here is a link to a thread i have started, it has pics of harness and connection for a emb setup http://www.mkivsupra.net/vbb/showthread.php?t=158378 Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 25, 2008 Share Posted August 25, 2008 Can someone confirm that this harness will clip into e manage blue models,and also is there better pictures of the white clip that supposed to clip to the ecu,device ect...thanks Matt's harness is definitely the correct type you'd need to easily wire in an E-manage or any other accessory. The white plug is something that the previous owner has wired in. It can be cut out and return the harness to standard without any problems. Quote Link to comment Share on other sites More sharing options...
