non-ABS ECU?
Homer
Excellent :) I know about the extra ABS ECU, but Gav mentioned the main ECU *might* be an issue, best to check before moving on! Thanks Jezz.
Hehehe, I meant, did you have the ABS ECU installed? The main ECU doesn't care either which way...also you will need to ensure that the abs rings connect up...not 100% sure where the picture on the loom...The two rear ones are easy to spot.. but I can't recall where the front's come in.
Ah right sorry Gav :D
All ABS wiring seems to be on a seperate loom to the engine one
Fair enough, I wasn't sure to be honest on that section.. I did plug in all three loom connectors. Just needs the ECU then.... Won't take long :)
ABS ECU is installed and wired up (was already on the car). I haven't tracked where the wiring goes, but will check if it goes to the ECU. However if Jezz says it doesn't matter than all should be well :)
