Slightly used HKS Triple Plate Clutch
StuartW
SOLD
2604-RT005 TOYOTA Supra 1993-1998 Turbo Triple Plate Pull Type 2JZ-GTE $2110.00
I bought this to go big manual Drag/road use but now have a drag Autobox and another supra!
It is used but plates are almost like new as of the rest of the kit.
it includes a light weight flywheel.
Asking £260
the pic is for reference but can take actual pic if required..its a tasty looking piece of kit!
I never had chance to fit it
Was it used by yourself? where did you get it from?
never used it myself as went with RPS Max as just bought a new OEM dual mass flywheel
Bought from coldflame on these forums and has been sitting in my garage, But now bigger things are on the cards:eyebrows:
more info
http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=1067
believed to be a quiet non chattery clutch,Dimitri replaces the stock bolt set with titanium but he does run over 1000HP with this!
Upon research before i bought it it is believed to have an almost stock feel and better than an uprated single pressure plate type.
My RPS is a bitch and makes my leg ache..also the bite on street is harsh!
it has the same action as standard (Think push) so i was told it will run std release bearing which it looks like it will.
If anyone wants pics this avo send me you mob no. as unable to post from home
Mine is 07788774991
