pezzler Posted August 7, 2008 Share Posted August 7, 2008 ive noticed a ticking noise coming from my engine. popped the bonnet and it appears to be comong from the inlet side (twin turbo), the ticking increases in speed with revs. anyone with any ideas?? it almost sounds like a quiet diesel.....which isnt good. Quote Link to comment Share on other sites More sharing options...
bignum Posted August 7, 2008 Share Posted August 7, 2008 Probably injectors, they are normally noisey like tappety sound Quote Link to comment Share on other sites More sharing options...
pezzler Posted August 7, 2008 Author Share Posted August 7, 2008 yeah, thought it may have been the injectors, just that ive never noticed it before, didnt notice it when i had my n/a either. oh well, maybe just paranoia! Quote Link to comment Share on other sites More sharing options...
bignum Posted August 7, 2008 Share Posted August 7, 2008 Does it quiten down as the car warms up? Quote Link to comment Share on other sites More sharing options...
R Black Posted August 8, 2008 Share Posted August 8, 2008 Does it quiten down as the car warms up? Mine also does this but not all the time? i only really notice it with the passenger window down, and it tends to go when warm. Quote Link to comment Share on other sites More sharing options...
pezzler Posted August 9, 2008 Author Share Posted August 9, 2008 i noticed the ticking noise when i switched the stereo off after a drive. so the engine was warm....gunna put it down to the injectors, after putting my ear to them, the noise appears to be coming from there. there we have it, sophisticated diagnostic equipment is the human ear Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 9, 2008 Share Posted August 9, 2008 Injectors You are driving a very well built Japanese car, not a Ford or a French car. Do not worry Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 9, 2008 Share Posted August 9, 2008 My aircon pump makes nasty ticky noises that rise with revs. Dodgy bearings that need dealing with at some point soon. Noises migrate. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 9, 2008 Share Posted August 9, 2008 You can check if it's injectors using the simple screwdriver trick. if the ticking is in time with the injectors then you know the cause. They do tend to tick a bit on the older cars, especially when hot. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 10, 2008 Share Posted August 10, 2008 It can also be incorrectly shimmed cams can't it? If you are worried you should get a reputable and knowledgeable place to have a proper listen to ease your mind or in fact to save you a huge repair bill if there is something wrong. Quote Link to comment Share on other sites More sharing options...
pezzler Posted August 12, 2008 Author Share Posted August 12, 2008 You can check if it's injectors using the simple screwdriver trick. if the ticking is in time with the injectors then you know the cause. They do tend to tick a bit on the older cars, especially when hot. screwdriver trick? Quote Link to comment Share on other sites More sharing options...
bignum Posted August 12, 2008 Share Posted August 12, 2008 Put the end of a long screwdriver on the area you think is making the noise and your earole on the end, Quote Link to comment Share on other sites More sharing options...
pezzler Posted August 13, 2008 Author Share Posted August 13, 2008 nice one. hope i done hear the ocean.. Quote Link to comment Share on other sites More sharing options...
GazB Posted August 13, 2008 Share Posted August 13, 2008 nice one. hope i done hear the ocean.. Or an alarm clock inside a crocodile Quote Link to comment Share on other sites More sharing options...
