StuartW Posted April 22, 2010 Author Share Posted April 22, 2010 Need to put the built engine in to rev higher Couple of vids first drive and walk around. http://www.youtube.com/user/seaworthymarine Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 22, 2010 Share Posted April 22, 2010 Is that RWHP? Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 23, 2010 Author Share Posted April 23, 2010 Is that RWHP? I wish, Actually just happy ATM that nothing broke. Still lots of tidying to do generally on the wiring. I was running a HKS 40mm WG and a Stuey special exhaust manifold, I have just purchased a HKS 60mm GT gate and manifold to flow better when we dyno with the built engine. Ryan did not spend too much time on trying to get max power out of my stock lump, The std engine ran very sweet and is a nice tight TT motor (Spare for white car:D) Last night was the first and last drive before i strip it tonight to make way for the built engine;) All in all im happy and the 2 speed transmission set up seems to all work sweet. Remember when it accelerates its only got 2 gears, 110MPH+ in low and 190+ in high. The pull seemed comparable to my white 6 speed T67 but totally constant on the power,Nose Lift all the way Even with only 600 fly hp she struggled for grip on the roads, Makes me think how LUSH she will be on the hot sticky black stuff with more power Quote Link to comment Share on other sites More sharing options...
MarkR Posted April 23, 2010 Share Posted April 23, 2010 That looks powerful Looking forward to the new engine! Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 23, 2010 Author Share Posted April 23, 2010 Just been to public weighbridge and was shocked. The car weighs with at least 40l of fuel 1220KG:Pling: I was questioning the accuracy of the bridge (S) so took my audi allroad down aswell, Sure enough they are spot on! They even weigh me accurately to within i would say 5kg, So i checked that its metric tonnes etc etc and sure enough it is. This is a real boost for me as i was expecting somewhere around 1500-1600. Anyone had any experience on public weighbridges. The plan earlier tonight, Before the mind bending drive i just had, Was to strip the engine out to have the Built engine put in, Then a re-dyno and off to the drag strips. I am curious to have a benchmark on 600hp because it sure is a handfull as is:cool: I am not patient enough to wait with the 600hp build til Shakey Mid May. Ideally some track time before then would be the ultimate answer. Anyone got any pointers. Does anyone have any idea of costs and notices needed to privately hire a strip for the day? Stu Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 23, 2010 Share Posted April 23, 2010 With that setup, weight/tyres/gearbox and power that will do an easy 10 second 1/4 id say, maybe even a 9. Looks to have a boost problem? 0.8 bar then rising to 1.7bar with the revs? explains why it looks so laggy in the graph, tbh i am supprised even as like that is not making a lot more power with a 74mm turbo. Quote Link to comment Share on other sites More sharing options...
dude Posted April 23, 2010 Share Posted April 23, 2010 Just been to public weighbridge and was shocked. The car weighs with at least 40l of fuel 1220KG:Pling: I was questioning the accuracy of the bridge (S) so took my audi allroad down aswell, Sure enough they are spot on! They even weigh me accurately to within i would say 5kg, So i checked that its metric tonnes etc etc and sure enough it is. This is a real boost for me as i was expecting somewhere around 1500-1600. Anyone had any experience on public weighbridges. The plan earlier tonight, Before the mind bending drive i just had, Was to strip the engine out to have the Built engine put in, Then a re-dyno and off to the drag strips. I am curious to have a benchmark on 600hp because it sure is a handfull as is:cool: I am not patient enough to wait with the 600hp build til Shakey Mid May. Ideally some track time before then would be the ultimate answer. Anyone got any pointers. Does anyone have any idea of costs and notices needed to privately hire a strip for the day? Stu About £3.5K I believe Quote Link to comment Share on other sites More sharing options...
GazB Posted April 23, 2010 Share Posted April 23, 2010 There's a meeting at York Raceway on May day bank holiday weekend but it would be a good travel for you You may have to wait until mid May for a normal track day event at Pod or Shakey unles you fancy spending big buck for private hire Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 23, 2010 Author Share Posted April 23, 2010 About £3.5K I believe Fancy goin halves dude:Pling: Joking BTW. I have emailed Pod and Shakey to see if i can enter in springspeed nats for testing..await reply Quote Link to comment Share on other sites More sharing options...
dude Posted April 24, 2010 Share Posted April 24, 2010 Fancy goin halves dude:Pling: Joking BTW. I have emailed Pod and Shakey to see if i can enter in springspeed nats for testing..await reply We are thinking about hiring the pod dude, if we do I'll let you know Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 27, 2010 Author Share Posted April 27, 2010 I have booked the 6th May with Hauser to set up and corner balance the car. Then off to pod for Friday king of the street. Have also entered HKS Drag series. The built engine is ever more nearing completion so i may keep the car together for the following weekend @ Shakey. Using and working around the car is allowing me to see the loose ends that need tidying. I have; Fitted Bleede valve to rear of cyl head. Finished wiring inside. Finished SPA fire extinguisher system install. Full fluids change. Using Shell Ultra 0-60 Race engine oil. Replaced front pads with The type top fuel methanol cars use (They are still pants) Familiarising myself with Laptop controls Minor window adjustments (As they keep blowing out @ 100+) Lexan colour coded sparks cover I have purchased a HKS Manifold and 60mm GT Wastegate that i might get time to fit before Pod. Replaced and colour coded all cooling hoses Double checked ALL soldered connections:rolleyes: Raised the nose for that extra MM of ground clearance i so desperately needed. Rebuilt the car trailer:rolleyes: All good Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 27, 2010 Author Share Posted April 27, 2010 I have booked the 6th May with Hauser to set up and corner balance the car. Then off to pod for Friday king of the street. Have also entered HKS Drag series. The built engine is ever more nearing completion so i may keep the car together for the following weekend @ Shakey. Using and working around the car is allowing me to see the loose ends that need tidying. I have; Fitted Bleede valve to rear of cyl head. Finished wiring inside. Finished SPA fire extinguisher system install. Full fluids change. Using Shell Ultra 0-60 Race engine oil. Replaced front pads with The type top fuel methanol cars use (They are still pants) Familiarising myself with Laptop controls Minor windor adjustments (As they keep blowing out @ 100+) Lexan colour coded sparks cover I have purchased a HKS Manifold and 60mm GT Wastegate that i might get time to fit before Pod. Replaced and colour coded all cooling hoses Double checked ALL soldered connections:rolleyes: Raised the nose for that extra MM of ground clearance i so desperately needed. Rebuilt the car trailer:rolleyes: Looking at setting up on VP race fuel All good Quote Link to comment Share on other sites More sharing options...
dude Posted April 28, 2010 Share Posted April 28, 2010 Stuart there is no event at the Pod on friday according to the calender, sat is test and tune and sunday is HKS race day, see you there, we are going up friday night. Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 28, 2010 Author Share Posted April 28, 2010 Stuart there is no event at the Pod on friday according to the calender, sat is test and tune and sunday is HKS race day, see you there, we are going up friday night. http://www.ptmshow.co.uk/ inc http://www.kingofthestreet.net/ on Friday I have spoken to the organizer (Lee Child) and its all on for Friday Quote Link to comment Share on other sites More sharing options...
dude Posted April 28, 2010 Share Posted April 28, 2010 http://www.ptmshow.co.uk/ inc http://www.kingofthestreet.net/ on Friday I have spoken to the organizer (Lee Child) and its all on for Friday I just spoke to the POD and they said nothing on till the sat in fact you cant even get into the pod till sat at 8 in the morning. Quote Link to comment Share on other sites More sharing options...
StuartW Posted April 28, 2010 Author Share Posted April 28, 2010 (edited) I just spoke to the POD and they said nothing on till the sat in fact you cant even get into the pod till sat at 8 in the morning. Just spoke again with Lee Child 07771590176 He reassures me that King of the Street is on the friday, With time slots on the Sat and Sun. He has also just called the POD office to re-confirm with the Person you just spoke to Dude. King of the street is a closed event to the public (Test day) and All you have to do to enter is fill in the online entry form or even better give Lee a call. http://www.kingofthestreet.net/ Entry fee is £100 but that covers Friday,Sat and Sunday.Driver and 2 crew. If you want to also enter RWYB then i think its an extra £10 to the POD My plan was to get maximum Track time over 3 days He said it would be nice (And very welcome) to see a few supra's there. Lee lives in the next town to me and Runs L.A. Racing parts and L.A.Racing promotions. Thanks Stu Edited April 28, 2010 by StuartW (see edit history) Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2010 Share Posted April 29, 2010 Just spoke again with Lee Child 07771590176 He reassures me that King of the Street is on the friday, With time slots on the Sat and Sun. He has also just called the POD office to re-confirm with the Person you just spoke to Dude. King of the street is a closed event to the public (Test day) and All you have to do to enter is fill in the online entry form or even better give Lee a call. http://www.kingofthestreet.net/ Entry fee is £100 but that covers Friday,Sat and Sunday.Driver and 2 crew. If you want to also enter RWYB then i think its an extra £10 to the POD My plan was to get maximum Track time over 3 days He said it would be nice (And very welcome) to see a few supra's there. Lee lives in the next town to me and Runs L.A. Racing parts and L.A.Racing promotions. Thanks Stu Cant do friday dude, thats my release day from Prison!!!!! so will see you there on the sat in the HKS pit. Quote Link to comment Share on other sites More sharing options...
Miguel Posted April 29, 2010 Share Posted April 29, 2010 Cant do friday dude, thats my release day from Prison!!!!! so will see you there on the sat in the HKS pit. For good? Quote Link to comment Share on other sites More sharing options...
SimonP Posted April 29, 2010 Share Posted April 29, 2010 Hi Stuart Good to see the car is nearly ready - looks fantastic. I am looking forward to hearing how you get on at the PTM show. Might see you at Shakey in mid May. Simon Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2010 Share Posted April 29, 2010 For good? Yes mate.............................hopefully;) Quote Link to comment Share on other sites More sharing options...
Miguel Posted April 29, 2010 Share Posted April 29, 2010 Yes mate.............................hopefully;) Sweet! Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 30, 2010 Share Posted April 30, 2010 Yes mate.............................hopefully;) For god sake don't wear one of those shirts. They're criminal. Quote Link to comment Share on other sites More sharing options...
Guest lee@streetnight Posted May 5, 2010 Share Posted May 5, 2010 See you friday Stuart, Not to late to book if anybody else is interested. Track will be fully prepped its bargain. these are my websites for anybody that doesn't know me:D http://www.kingofthestreet.net http://www.streetnights.com http://www.laracingparts.com and i am a distributor for VP Racing Fuels Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted May 6, 2010 Share Posted May 6, 2010 This car is going to be mental with 1000+hp with 700hp last night it was just epic! The Glide box is just awesome! Launching with 1.6bar also is neck breaking See you friday Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted May 7, 2010 Share Posted May 7, 2010 Stu just run a 9.8 @147mph Stock bad for a stock engine and 1.5bar on a t74 Quote Link to comment Share on other sites More sharing options...
