dude Posted March 20, 2011 Share Posted March 20, 2011 I am hoping to get to my chassis tag of 8.5 Seconds, Will be around 170mph, i should have 500 more hp! If i run faster than 8.5 twice i am banned for safety reasons! It would be cool as chips to set up the Dash 2 with a 8 second warning timer so i have to break before the finish line. In drag racing that style is a whole world called "Bracket Racing" But you would limit your time with throttle stop and not your right foot. Link to comment Share on other sites More sharing options...
StuartW Posted March 20, 2011 Author Share Posted March 20, 2011 Dont you know i only have 2 throttle positions. On/OFF (";)...but yes a very valid point that could be used if needed. Probably a good idea to lessen the "Strain" on driveline components too. Link to comment Share on other sites More sharing options...
mark newman Posted March 20, 2011 Share Posted March 20, 2011 Looking good stuart will you be ready Link to comment Share on other sites More sharing options...
GazB Posted April 1, 2011 Share Posted April 1, 2011 Any updates? I see you have entered Easter Thunderball at Pod Link to comment Share on other sites More sharing options...
StuartW Posted April 3, 2011 Author Share Posted April 3, 2011 Hi All, I am after a set of std ACl race series big end and mains (Big end is priortiy) ASAP as had a lil mis hap when assembling the built engine. (Actually only need 1 Journal set) or does anyone know a Uk supplier? I have googled and ebayed with no avail Flat out on the build now will update asap with pics..Dyno booked @TDI (Hub dyno) on the friday 15th, then off for test and tune weekend @ pod...Fingers crossed!!! Thanks Link to comment Share on other sites More sharing options...
StuartW Posted April 4, 2011 Author Share Posted April 4, 2011 Link to issues i have been having with the cranks... http://www.mkivsupra.net/vbb/showthread.php?243244-ACL-std-Race-bearings Link to comment Share on other sites More sharing options...
StuartW Posted April 13, 2011 Author Share Posted April 13, 2011 Well its been a very long story but we are loaded ready to aim for Torque developments international thursday14th the car has had a 50 mile road test/run in with no major faults! planning to unload it from the transporter and drive it the lst 100 miles (if dry) to dyno to complete the running in of the engine!! Then (fingers crossed everything goes well) off to pod for a weekende of test and tune ;-) got loads of progressive build pics to add asap. Got a full wizards of nos install, wish myself the team and RyanG good luck..fingers and everything crossed zzz Link to comment Share on other sites More sharing options...
Ryan.G Posted April 14, 2011 Share Posted April 14, 2011 Just leaving Tdi now and we managed to be the first to overpower Tdi's Dyno Last reading we got at 1.8bar was 810 at the hubs on esso 97 fuel any more boost and the packs slipped at peak torque. I need a t6 turbo in my life. Full boost at 5k aswell which is amazing! Bring on 2.5bar at pod on sat with nitrous! Link to comment Share on other sites More sharing options...
Scott Posted April 14, 2011 Share Posted April 14, 2011 Ooooooooooooo, in for the updates Link to comment Share on other sites More sharing options...
JamieP Posted April 15, 2011 Share Posted April 15, 2011 Oh great, another dyno that turns out to be no good. Link to comment Share on other sites More sharing options...
dude Posted April 15, 2011 Share Posted April 15, 2011 Oh great, another dyno that turns out to be no good. I'll be spraying my tires with evo stick and taping matt into the seat to do mine on our dyno !!!!!!! Did they give a reason as 810 is not a great deal in the scheme of things, when Stu cranks the boost up it will be way more. Link to comment Share on other sites More sharing options...
Ryan.G Posted April 15, 2011 Share Posted April 15, 2011 (edited) Oh great, another dyno that turns out to be no good. On a v160 it will be fine in 5th or 6th as the ratio is not 1:1.. but on a 2 speed glide box with a gear ratio of 1:1 ratio in 2nd, the delta torque is massive. It was nearly producing 800kw of energy!!! Joys of auto's and Torque convertors But the dyno is the only one in the UK that will do as well as it did last night. We were doing 30 second runs! So if you think normally stu's car would do a quater mile in under 10 seconds in both gears.... just how hard the packs would have to have been working to hold the torque back to make a run 30seconds so we could a.) get map perfect b.) know if it did a top speed run to 200+ it would be fine. The dyno worked so well last night that now i have a volume efficiency plot laid out for up to 3bar. All the rest of the tuning is now done on the strip. Well a 1am finish and now back off to work! Edited April 15, 2011 by Ryan.G (see edit history) Link to comment Share on other sites More sharing options...
Ryan.G Posted April 15, 2011 Share Posted April 15, 2011 I'll be spraying my tires with evo stick and taping matt into the seat to do mine on our dyno !!!!!!! Did they give a reason as 810 is not a great deal in the scheme of things, when Stu cranks the boost up it will be way more. You coming sat? Link to comment Share on other sites More sharing options...
dude Posted April 15, 2011 Share Posted April 15, 2011 You coming sat? No dude, we are flat out on the race car, just about on schedule, I'll have to use the thunderball as a shakedown meeting. Link to comment Share on other sites More sharing options...
Wez Posted April 15, 2011 Share Posted April 15, 2011 On a v160 it will be fine in 5th or 6th as the ratio is not 1:1.. but on a 2 speed glide box with a gear ratio of 1:1 ratio in 2nd, the delta torque is massive. It was nearly producing 800kw of energy!!! Joys of auto's and Torque convertors But the dyno is the only one in the UK that will do as well as it did last night. We were doing 30 second runs! So if you think normally stu's car would do a quater mile in under 10 seconds in both gears.... just how hard the packs would have to have been working to hold the torque back to make a run 30seconds so we could a.) get map perfect b.) know if it did a top speed run to 200+ it would be fine. The dyno worked so well last night that now i have a volume efficiency plot laid out for up to 3bar. All the rest of the tuning is now done on the strip. Well a 1am finish and now back off to work! Sounds good matey Link to comment Share on other sites More sharing options...
StuartW Posted April 17, 2011 Author Share Posted April 17, 2011 The first vid from the dyno is now on my you tube 8300rpm flames! http://www.youtube.com/user/seaworthymarine?feature=mhum#p/u/6/d-Ka_1JS0Xc can someone embed please? Link to comment Share on other sites More sharing options...
scotty71 Posted April 17, 2011 Share Posted April 17, 2011 d-Ka_1JS0Xc Link to comment Share on other sites More sharing options...
StuartW Posted April 17, 2011 Author Share Posted April 17, 2011 (edited) BTW tomorrow should have the first vids of it ripping up the track! We tested yesterday and got a 10 sec flat, lots to set up with the nos etc. Had boost creep so need a bigger waste gate, currently have a tial 44mm but have a 60mm gate at the workshop. will fit for next weekend. We stripped off the hotside and have it now back at the workshops in teignmouth. The car and camper are stored at the pod for the 4 day national starting racing this Friday 9am. RyanG mental; http://www.youtube.com/user/seaworthymarine?feature=mhum#p/u/6/54ODTL61m9U Big Big Thank you to Sam @TDI and especially RyanG who's efforts have been EPIC to match the words i cannot find to describe how happy i am that the ol gal did not have a single hitch in her shakedown's Smiles for miles man... Edited April 17, 2011 by StuartW (see edit history) Link to comment Share on other sites More sharing options...
StuartW Posted April 17, 2011 Author Share Posted April 17, 2011 i had some serious issues with ground clearance so flipped the rear shock brackets the other way around and heated the Exhaust to cherry red, a few hits later and we had 2" clearance That is a Burns stainless silencer in there as it is road legal of course ocifer Link to comment Share on other sites More sharing options...
Ryan.G Posted April 24, 2011 Share Posted April 24, 2011 9.088 @157 Mph 8's tomorrow hopefully!!! after we have now got the turbo spooling on the line and finally getting some grip!! Link to comment Share on other sites More sharing options...
JamieP Posted April 24, 2011 Share Posted April 24, 2011 Well done guys, best of luck for tomorrow:) Link to comment Share on other sites More sharing options...
Ryan.G Posted April 24, 2011 Share Posted April 24, 2011 Just to add this is on road tyres and v power fuel as its competing in the street elimitor series Link to comment Share on other sites More sharing options...
JustGav Posted April 24, 2011 Share Posted April 24, 2011 Homer mentioned this to me earlier Really well done guys Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 24, 2011 Share Posted April 24, 2011 Wow nice work. Link to comment Share on other sites More sharing options...
Lee P Posted April 24, 2011 Share Posted April 24, 2011 Well done guys great result Link to comment Share on other sites More sharing options...
