Pudsey Posted March 25, 2010 Share Posted March 25, 2010 Doing some 'Awesome' work there Stuart (for want of a better word.... I know you will get that even if no one else does). The car is even better in the flesh, I could have spent hours looking at it. Certaining aww inspiring, I too can't wait to see you up and running........... do you need a camera man for this one too? wink wink..... Link to comment Share on other sites More sharing options...
dude Posted March 26, 2010 Share Posted March 26, 2010 How come you have put the reg on the fuel rail?? or is it a single feed in at the front?? the reg normally goes on the return, if you are dual feed are you sure it will still work ok. Link to comment Share on other sites More sharing options...
StuartW Posted March 26, 2010 Author Share Posted March 26, 2010 dude said: How come you have put the reg on the fuel rail?? or is it a single feed in at the front?? the reg normally goes on the return, if you are dual feed are you sure it will still work ok. Andy frost did it. I have a single -10 feed @ front, Works fine. My Road T67 has fuel feeds both ends and a return in the middle. I am getting aerated fuel when i run below 1/4 a tank. The theory behind doing it this way is that you get less Aeration/cavitation and when pulling foreward G's the fuel is helped to get pulled through the rail! Andy runs the same system albeit twin on his 9.3L V8 TT 2,400BHP engine. The car still needs a lot of fettling. Just getting a feel for where everything needs to be located and relocated ...But on it flat out hoping for a shakedown (weather permitting) in the very near future Link to comment Share on other sites More sharing options...
GazB Posted March 26, 2010 Share Posted March 26, 2010 Looking good Stu How near till shake down? Will 1st round be the date http://prostreetdragseriesuk.freeforums.org/2010-psds-dates-t567.html or is Pod the more likely venue? Gaz Link to comment Share on other sites More sharing options...
StuartW Posted March 26, 2010 Author Share Posted March 26, 2010 GazB said: Looking good Stu How near till shake down? Will 1st round be the date http://prostreetdragseriesuk.freeforums.org/2010-psds-dates-t567.html or is Pod the more likely venue? Gaz Should be on the road by next weekend Hoping to be confident enough to run the first round @ Shakey 17th/18th April Shakey will be my preferance as only 300 mile round trip compared to 500+ miles for pod. Link to comment Share on other sites More sharing options...
James Posted March 26, 2010 Share Posted March 26, 2010 Just read this right through for the first time! This is brilliant! I'd take off the "horned" badges though and replace with normal emblems - you'll save some weight that way too Link to comment Share on other sites More sharing options...
GazB Posted March 26, 2010 Share Posted March 26, 2010 StuartW said: Should be on the road by next weekend Hoping to be confident enough to run the first round @ Shakey 17th/18th April Shakey will be my preferance as only 300 mile round trip compared to 500+ miles for pod. Nice If all goes well i'll see you there then and i shall make sure i have my video with me Link to comment Share on other sites More sharing options...
StuartW Posted March 26, 2010 Author Share Posted March 26, 2010 HateEvent said: Just read this right through for the first time! This is brilliant! I'd take off the "horned" badges though and replace with normal emblems - you'll save some weight that way too They are now black...Far less orrible Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 26, 2010 Share Posted March 26, 2010 looking good mate, thumbs up Link to comment Share on other sites More sharing options...
dude Posted March 26, 2010 Share Posted March 26, 2010 StuartW said: Andy frost did it. I have a single -10 feed @ front, Works fine. My Road T67 has fuel feeds both ends and a return in the middle. I am getting aerated fuel when i run below 1/4 a tank. The theory behind doing it this way is that you get less Aeration/cavitation and when pulling foreward G's the fuel is helped to get pulled through the rail! Andy runs the same system albeit twin on his 9.3L V8 TT 2,400BHP engine. The car still needs a lot of fettling. Just getting a feel for where everything needs to be located and relocated ...But on it flat out hoping for a shakedown (weather permitting) in the very near future I see what he has done, quite a good idea, by going -10 into the front you can use the rear as the return and just screw the reg in there, if I were starting from scratch I would try that myself. What times do you reckon this will run??? If Dave Price's car gets here in time we might have some quick cars out this year, judging by the surface at the pod we may have some expensive repair bills too!!! Link to comment Share on other sites More sharing options...
StuartW Posted March 26, 2010 Author Share Posted March 26, 2010 Desperate for an IAT (Inlet air temperature) sensor, They are £50+ from toyota! Can anyone help Link to my lonely wanted thread http://www.mkivsupra.net/vbb/showthread.php?p=2706571#post2706571 Link to comment Share on other sites More sharing options...
StuartW Posted March 28, 2010 Author Share Posted March 28, 2010 Finally sorted the lack of spark, I forgot to plug the injector harness back in after wiring in the resistor pack Link to comment Share on other sites More sharing options...
MarkR Posted March 28, 2010 Share Posted March 28, 2010 w4TiPe_r7LI Nice Here it is embedded... Link to comment Share on other sites More sharing options...
Ryan.G Posted March 28, 2010 Share Posted March 28, 2010 Glad it runs on the base map and loom Stu Link to comment Share on other sites More sharing options...
StuartW Posted March 29, 2010 Author Share Posted March 29, 2010 Ryan.G said: Glad it runs on the base map and loom Stu Many Thanks Ryan..Top banana Link to comment Share on other sites More sharing options...
Guest The caddy man Posted March 29, 2010 Share Posted March 29, 2010 lovely supra m8 Link to comment Share on other sites More sharing options...
StuartW Posted April 10, 2010 Author Share Posted April 10, 2010 (edited) :d Edited April 12, 2010 by StuartW (see edit history) Link to comment Share on other sites More sharing options...
AshBhp Posted April 10, 2010 Share Posted April 10, 2010 I look forward to see her run on 19th at Shakes, will say hello as we will be running our Civic. Link to comment Share on other sites More sharing options...
StuartW Posted April 10, 2010 Author Share Posted April 10, 2010 AshBhp said: I look forward to see her run on 19th at Shakes, will say hello as we will be running our Civic. 19th is Monday, Unfortunately i will not be there, On Tuesday 20th Got Ryan booked for a long day tidying wiring and a dyno Still a lot of sortin of loose ends to do, Then a Day with a drag suspension specialist to set up the rear end. I should be good for May 15/16th weekend @ Shakey. I WILL NEVER UNDER ESTIMATE JUST HOW MUCH WORK GOES INTO BUILDING A CAR AGAIN Link to comment Share on other sites More sharing options...
JamieP Posted April 10, 2010 Share Posted April 10, 2010 Well done Stuart, looks to have come together well, going to be some serious machines at this years suprapod i think. Link to comment Share on other sites More sharing options...
Homer Posted April 10, 2010 Share Posted April 10, 2010 That looks awesome, is there anything stock in that car at all! I think you made a mistake on the last edit though I'm seeing a pic of dudes car instead of yours As Jamie said, Suprapod should be interesting this year! Link to comment Share on other sites More sharing options...
Thorin Posted April 12, 2010 Share Posted April 12, 2010 Very purposeful looking! Look forward to seeing the videos of it run. Link to comment Share on other sites More sharing options...
StuartW Posted April 12, 2010 Author Share Posted April 12, 2010 Ok Well i have hit another hurdle, The exhaust has to exit through to rear of car as i cannot run a wing exited 5" system without major mods, ie moving brake servo or cutting through chassis member! SO i have a 4" Boostlogic downpipe and mid pipe that currently runs to just behind the seats (2nd catback) I need to source a 4" catback exhaust or silencer to finish the exhaust for road useage. I did struggle on my white car to find a true "Free flowing" 4" ID silencer and backbox. My plans would be to have the 2 slinecers removable for the strip. I am looking into truck exhausts suppliers to see if they can help. In the meantime i will post in wanted for a 4" ID system, But i will have to cut it about anyways as the Hauser chassis rail severely limits ground clearance and Pipework routing. I might experiment with some 4" Truck flexi stuff and see how i get on...In the meanwhile any suggestions greatfully received as i am too close to mapping to fall at this hurdle:innocent: Link to comment Share on other sites More sharing options...
MarkR Posted April 12, 2010 Share Posted April 12, 2010 StuartW said: Ok Well i have hit another hurdle, The exhaust has to exit through to rear of car as i cannot run a wing exited 5" system without major mods, ie moving brake servo or cutting through chassis member! SO i have a 4" Boostlogic downpipe and mid pipe that currently runs to just behind the seats (2nd catback) I need to source a 4" catback exhaust or silencer to finish the exhaust for road useage. I did struggle on my white car to find a true "Free flowing" 4" ID silencer and backbox. My plans would be to have the 2 slinecers removable for the strip. I am looking into truck exhausts suppliers to see if they can help. In the meantime i will post in wanted for a 4" ID system, But i will have to cut it about anyways as the Hauser chassis rail severely limits ground clearance and Pipework routing. I might experiment with some 4" Truck flexi stuff and see how i get on...In the meanwhile any suggestions greatfully received as i am too close to mapping to fall at this hurdle:innocent: Why not just make one? Have you asked Paul Whiffin? He has them made and can possibly point you in the right direction? Link to comment Share on other sites More sharing options...
dude Posted April 12, 2010 Share Posted April 12, 2010 http://www.burnsstainless.com/ Link to comment Share on other sites More sharing options...
