StuartW Posted October 7, 2008 Author Share Posted October 7, 2008 that looks awesome dude! Will have a hunt in the garage may have some bits and bobs from my old supra. Did you have that hunt mate? Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 7, 2008 Share Posted October 7, 2008 (edited) You might want to speak to Gas Motorsport in OZ. http://www.gasmotorsport.com.au They build 1600 rwhp 2JZ's using custom Mark "Mr Turbo" Kitchen Turbo's. Lyndon. Edited October 7, 2008 by Lyndon @ Rogue (see edit history) Quote Link to comment Share on other sites More sharing options...
StuartW Posted October 13, 2008 Author Share Posted October 13, 2008 Okay i have finally broken up and got rid of the TT Shell, Thus gained some workshop space, funds and parts! I have sourced some of the following and would appreciate Anyones thoughts before i go ahead and commit. CP +0.20 Pistons Around £500 new carillo Rods ARP head and main bolts Clevite bearings Does anyone have experience of Eagle rods over Carillo Carillo's cost around £1000 or a used set for £350? Eagles around £350 new? Any other reliable piston choices? So i guess the BIG Q is has anyone tested Eagles to distruction? Thoughts appreciated... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 13, 2008 Share Posted October 13, 2008 So you are REALLY considering building a serious race engine and putting in some Chinese rods??? I would definitely go for branded rods, and new ones. You just don't know what over revs a rod has had bought second hand. Carrillo, Farndon, Tomei, Cosworth and Arrow all make known good rods, either custom or off the shelf. There are a lot of Eagle copies around, too, if you decided the "real" Eagle rods were worth a go. It's a shame no one seems to make a forged piston for the 2JZ engines with a coolant channel in the crown, like the stock cast ones. Tomei do them for the RB series, but not the 2JZ lumps. They pull a vast amount of heat from the crowns and the ring packs. Quote Link to comment Share on other sites More sharing options...
StuartW Posted October 14, 2008 Author Share Posted October 14, 2008 So you are REALLY considering building a serious race engine and putting in some Chinese rods??? I would definitely go for branded rods, and new ones. You just don't know what over revs a rod has had bought second hand. Carrillo, Farndon, Tomei, Cosworth and Arrow all make known good rods, either custom or off the shelf. There are a lot of Eagle copies around, too, if you decided the "real" Eagle rods were worth a go. It's a shame no one seems to make a forged piston for the 2JZ engines with a coolant channel in the crown, like the stock cast ones. Tomei do them for the RB series, but not the 2JZ lumps. They pull a vast amount of heat from the crowns and the ring packs. Carillo's it is then! I really appreciate this sort of feed back...Saves Massive £££££££££'s in the long run:cool: Can the channel be copied from stock and created by a really good machinist? Can you give me a heads up list of good quality pistons please Quote Link to comment Share on other sites More sharing options...
Wez Posted October 14, 2008 Share Posted October 14, 2008 Can you give me a heads up list of good quality pistons please JUN/Cosworth Quote Link to comment Share on other sites More sharing options...
bolarbag Posted October 14, 2008 Share Posted October 14, 2008 I agree Jun/Cosworth, but not speaking from personal experience more of an unorthodox standpoint, would it not be better - certainly cheaper to rag an oem block to its death (depending on the power output required) each time than to build a overly expensive block thats bound to fail anyway? I never was of that opinion until a member on here Robbie mentioned that his 3.2 L Jun block threw up various problems, he ran a very low time on a full weight sup, let alone a full drag car You could easily spend 3-4K on exotic parts for the block alone, thats probably 8 used blocks there;) Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 14, 2008 Share Posted October 14, 2008 JUN/Cosworth Nice but £1200 a set:( Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 14, 2008 Share Posted October 14, 2008 I agree Jun/Cosworth, but not speaking from personal experience more of an unorthodox standpoint, would it not be better - certainly cheaper to rag an oem block to its death (depending on the power output required) each time than to build a overly expensive block thats bound to fail anyway? I never was of that opinion until a member on here Robbie mentioned that his 3.2 L Jun block threw up various problems, he ran a very low time on a full weight sup, let alone a full drag car You could easily spend 3-4K on exotic parts for the block alone, thats probably 8 used blocks there;) Very good point and along the lines im thinking now, Ryan is mapping my stock engine to 2bar on race fuel friday, lets see how long that lasts;) Quote Link to comment Share on other sites More sharing options...
Steve Posted October 14, 2008 Share Posted October 14, 2008 Very good point and along the lines im thinking now, Ryan is mapping my stock engine to 2bar on race fuel friday, lets see how long that lasts;) Nutter Quote Link to comment Share on other sites More sharing options...
MarkR Posted October 14, 2008 Share Posted October 14, 2008 Nutter My thoughts exactly Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 14, 2008 Share Posted October 14, 2008 Definatly carrillo rods and I would use better pistons too. As Chris has said before the cp's and made of crapy material and the rings are generic and need fileing. With the money going into the build I would use Jun/Cosworth or HKS, the Malhe pistons are very good. If you want to buy cheaper pistons then wiseco would be a better choice over cp anyday Quote Link to comment Share on other sites More sharing options...
bolarbag Posted October 14, 2008 Share Posted October 14, 2008 Very good point and along the lines im thinking now, Ryan is mapping my stock engine to 2bar on race fuel friday, lets see how long that lasts;) If it gets by the mapping session probably longer than you think;) 2Bar's a little excessive lol, but you get the jist, even with a broken block it could probably be sold on in bits anyway, so not a total loss, a good set of forged conrods would add a little reliability if need be I'd love to see the results of that t67 at 2bar:d Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 14, 2008 Share Posted October 14, 2008 Would like to have got the water injection on before the you start running 2bar but we will see lol Quote Link to comment Share on other sites More sharing options...
StuartW Posted October 14, 2008 Author Share Posted October 14, 2008 (edited) Well i defo need a built head (ferrara valve train) all in with machine work approx £700) To allow me the revs needed to achieve 800-900hp, therefore i do not want a rod to let go and write off the head parts? Also after a well serviced season of drag and track (With small NOS 60hp dynoed shot) My std engine is breathing heavily and loosing compression fast...The point being with the 2k higher revs and increased stresses i don't think i can realistically look at pushing more than 600hp tops:search: Unless anyone else has a success story? The car is well mapped and shows good AFR and EGT's and always has (Although maybe a little rich may have caused bore wash and premature wear?) That would make a pretty sedate halfback Houser Race car!...But points of view taken on board. Edited October 14, 2008 by StuartW (see edit history) Quote Link to comment Share on other sites More sharing options...
StuartW Posted October 15, 2008 Author Share Posted October 15, 2008 (edited) Would like to have got the water injection on before the you start running 2bar but we will see lol All interesting and my brain is like a sponge ATM. Interesting comments on the wiseco pistons. Now need to think about *4" Pipework from BL intercooler to Veilside TB *Any thoughts on Mazure electric waterpumps? Remember i have AEM now to control it and time its running after shut off. *Injectors, 1600cc is RC the only contendor? *water injection kits? any good proven systems? any for sale? Edited October 15, 2008 by StuartW (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest WDFL12 Posted October 15, 2008 Share Posted October 15, 2008 Hi nothing wrong with cp pistons , afterall thats whats in the 7.7 sec Sups . I No as i build it . Yes the rings are genetic but it depends on the application so its down to personal choice i guess . Quote Link to comment Share on other sites More sharing options...
StuartW Posted December 4, 2008 Author Share Posted December 4, 2008 (edited) Strange Pro series Race brakes arrived 11 1/4" Rotors the whole set up weighs 33Lbs! 100mm Throttle body with TPS fitted Mazuire electric pump TRD Engine mounts The Head has gone off for machine work to accommodate full ferrera valve train inc dual springs. The Block is being bored for the Wiseco 86.5mm Pistons All Plexi glass and door trims are in and finished Really stonkin on now... Edited April 1, 2009 by StuartW (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 7, 2008 Share Posted December 7, 2008 I like the brakes, nice weight saving. Nice to see you are buying quality parts for the car:) Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted December 7, 2008 Share Posted December 7, 2008 Stuart, Can you get some pics of your Lexan windows up please mate Ryan Quote Link to comment Share on other sites More sharing options...
GazB Posted December 7, 2008 Share Posted December 7, 2008 Looking nice Stuart, when and where is first outing planned? This looks good value at £60 Santa Pod Raceway invites drivers & riders to the Peak Performance Days held on: Saturday 4th April 2009 Quote Link to comment Share on other sites More sharing options...
StuartW Posted December 8, 2008 Author Share Posted December 8, 2008 Looking nice Stuart, when and where is first outing planned? This looks good value at £60 Santa Pod Raceway invites drivers & riders to the Peak Performance Days held on: Saturday 4th April 2009 Yes Gaz if i can make that i will! Fitted all the brakes on Friday, Had to machine the spacers from 15mm to 6mm to clear the arches as this car is slammed. This meant re spacing all the caliper brackets as well Carillo H beam rods arrived today Ryan..Hopefully i will get some pics up of the windows this week. Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2008 Share Posted December 8, 2008 Are them rods used? Quote Link to comment Share on other sites More sharing options...
Lee P Posted December 8, 2008 Share Posted December 8, 2008 Nice to see you are buying quality parts for the car:) Except for the ebay manifold, you will want to put lots of sealent on that manifold before you put it together. Its a PITA to take it on/off with the engine in so get it on right the first time with the engine out. Quote Link to comment Share on other sites More sharing options...
StuartW Posted December 8, 2008 Author Share Posted December 8, 2008 Except for the ebay manifold, you will want to put lots of sealent on that manifold before you put it together. Its a PITA to take it on/off with the engine in so get it on right the first time with the engine out. cheers for that, is there a easier mani to access? The faces will be milled and carefully checked before assembly and leak tested regularly;) Quote Link to comment Share on other sites More sharing options...
