Terminator Posted August 7, 2008 Share Posted August 7, 2008 Now I have a manual and a big single, I want to compare RL and AEM traction control systems. Is any one here using AEM traction control. If so would you be will to share your settings? Quote Link to comment Share on other sites More sharing options...
bignum Posted August 7, 2008 Share Posted August 7, 2008 I don`t think anyone uses it on the aem, aparently its not that good anyway, Quote Link to comment Share on other sites More sharing options...
jamesmark Posted August 7, 2008 Share Posted August 7, 2008 The Motec ECU is meant to have a good traction control, I think it was Gaz1 that mentioned (not 100%). Wez has just installed a new ECU Solaris S6GP, the TC on that is meant to be mors advanced than RLTC. http://www.mkivsupra.net/vbb/showthread.php?t=158573 Maybe pointless info if you're only wanting AEM Vs RLTC, but am bored. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 7, 2008 Share Posted August 7, 2008 I never got round to trying the AEM traction, with some time spent it was supposed to work ok. Here are the settings I was going to use as a starting point, you can also wire in a varible pot to give easy in car adjustment. Quote Link to comment Share on other sites More sharing options...
Terminator Posted August 7, 2008 Author Share Posted August 7, 2008 Thanks Wez much appreciated. I am keeping an open mind as far as AEM is concerned. I did quite a bit of testing of RLTC back in 2001. I just want to see what can be done with AEM TC with a bit of effort. Quote Link to comment Share on other sites More sharing options...
paul mac Posted August 8, 2008 Share Posted August 8, 2008 whoa there Termy your the forum RLTC guru you cant starting using anything else, we need you Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted August 8, 2008 Share Posted August 8, 2008 whoa there Termy your the forum RLTC guru you cant starting using anything else, we need you but what if it's better Phil, will be very interested to hear your findings. Mike Quote Link to comment Share on other sites More sharing options...
Gerry Posted August 8, 2008 Share Posted August 8, 2008 Pleased to see that "The Gumpert" uses racelogic as well See Topgear last episode. The Gumpert: http://www.gumpert.de/eng/index_html.html Quote Link to comment Share on other sites More sharing options...
paul mac Posted August 9, 2008 Share Posted August 9, 2008 but what if it's better at 1.4 bar boost RLTC will hold my car in a straight line in p***ing rain, it does'nt get any better than that Quote Link to comment Share on other sites More sharing options...
