Jim_1979 Posted August 5, 2008 Share Posted August 5, 2008 Looking to remove the tailgate completley so I can do some work on the car. Curious as to how you go about it? anyone? Quote Link to comment Share on other sites More sharing options...
michael Posted August 5, 2008 Share Posted August 5, 2008 I found that the easiest way is to remove it with the hinges still attached - pull the headlining down at the back of the car to reveal the 2 nuts on each side, undo these and then lift the hatch clear. Having the hinges on also makes it easier when refitting IMO, You'll need to undo the lifters too obviously. Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted August 5, 2008 Share Posted August 5, 2008 Yup i remember doing it on my own and nearly breaking my back:D before you try to remove the lid, id suggest having someone to help you as its kinda 'heavy' Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 6, 2008 Share Posted August 6, 2008 I found that the easiest way is to remove it with the hinges still attached - pull the headlining down at the back of the car to reveal the 2 nuts on each side, undo these and then lift the hatch clear. Having the hinges on also makes it easier when refitting IMO, You'll need to undo the lifters too obviously. Also helps if you disconnect the wiring harness plugs to;) Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted August 6, 2008 Author Share Posted August 6, 2008 cheers chaps Quote Link to comment Share on other sites More sharing options...
michael Posted August 6, 2008 Share Posted August 6, 2008 Also helps if you disconnect the wiring harness plugs to;) Certain things I leave to common sense. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 6, 2008 Share Posted August 6, 2008 Certain things I leave to common sense. Hmm! supra owners, common sense, interesting concept:innocent: Quote Link to comment Share on other sites More sharing options...
michael Posted August 6, 2008 Share Posted August 6, 2008 Hmm! supra owners, common sense, interesting concept:innocent: Yeah, I forget sometimes Quote Link to comment Share on other sites More sharing options...
Guest jonte_j Posted January 4, 2009 Share Posted January 4, 2009 Also helps if you disconnect the wiring harness plugs to;) Where are these plugs? under the headliner or inside the tailgate? Quote Link to comment Share on other sites More sharing options...
Lukeyboy2k Posted January 4, 2009 Share Posted January 4, 2009 Where are these plugs? under the headliner or inside the tailgate? Inside the tailgate. I found the one on the drivers side very easy, but I couldn't unclip the passenger side so ended up having to cut the wires before soldering them back together when replacing the tailgate. Quote Link to comment Share on other sites More sharing options...
