hadyn Posted August 5, 2008 Share Posted August 5, 2008 Quick question. When fitting the blitz 2nd decat does the O-ring type gasket that goes on the flange that mounts to the first cat do you just leave it free when fitting or do you need to stick it to the flange? Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 8, 2008 Author Share Posted August 8, 2008 Right fitte today no problems. However the decat doesnt seem to meet up flange to flange with the 1st cat but instead relies on the o ring gasket to make up the small gap between the decat and 1st cat flanges? Is that right or do both decat and 1st cat need to be flange to flange? Car seems to run fine, no blowing etc. Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 8, 2008 Author Share Posted August 8, 2008 Does this look OK to you guys? Quote Link to comment Share on other sites More sharing options...
simbasupra Posted August 8, 2008 Share Posted August 8, 2008 any chance of a clearer pic? Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 8, 2008 Author Share Posted August 8, 2008 You should be able to see the gap between the two flanges. Within that the o-ring type gasket is fitted which mates to the first cat. Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 8, 2008 Author Share Posted August 8, 2008 My main question is do I need to tighten any further (gasket feels tight)? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 8, 2008 Share Posted August 8, 2008 If its all tweaked up tight and its not blowing then it should be fine. Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 8, 2008 Author Share Posted August 8, 2008 If its all tweaked up tight and its not blowing then it should be fine. Thats good news. I just find it weird as I've never come across an exhaust part where the two flanges dont completely meet up. Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 9, 2008 Author Share Posted August 9, 2008 Anyone else have any thoughts about this fitment? Quote Link to comment Share on other sites More sharing options...
AndyT Posted August 9, 2008 Share Posted August 9, 2008 Doubt you'll be able to compress the gasket fully bud. As long as the gap is even all round it's sealed and should be good. My only thought was that you tightened the other end first and not left enough play to tighten that flange but since it's not blowing it's not a concern. Quick question. Does the gasket not sit in a recess in the flange? I haven't taken one apart. Quote Link to comment Share on other sites More sharing options...
