Federal Tyres
Guest Garfy
Guest Garfy
has anyone ever fitted Federal 595's to their supra?
If so I'd be intersted to hear your thoughts, I know they are not the best tyre in the world, but for cost reasons I have fitted them to my Supra, before I report I would like to hear someone else's experiance of them.
Thanks
Garath
Guest Garfy
I know what you are saying here, but I've always fitted Falkens in the past and they have been fine, these were a similar price.
Now, the reason I'm asking this question is, my car feels strange, it grips well enough, infact I would say it has more grip than with the Falkens, but it just feels weird, vague is the best way to describe it, but, a few things have been changed on the car recently, I've uprated the brakes, lowered the back end a little (because that has always felt very light) and because the brakes now work properly (for the first time since I've owned the car) I have been pushing it more, so before I put the blame on the tyres and shell out money for replacements, I need to know that they are at fault, the thing is, the front ones have been on there for some 5 months, its only the rears I put on Monday.
I'm hoping to get all the geo checked this week, maybe thats out, well it is out, because its always scrubed the inside edge of the fronts, so much so that it wears fronts out before the backs, the only thing I have noticed about these tyres is that if I place my foot on the sideway at the top of the wheel (while on the car) and push, it seems very easy to flex the sidewall, but then I never tried that on the falkens, so I have no comparison.
I am tempted to throw them away and buy some falkens though, but I dont want to do that if its something else thats causing it.
Edited by Garfy (see edit history)
Guest Garfy
oh, and another question, have I got the size's right?
255/35/18 rear
235/40/18 front
it did have 265/35/18 on the rear before, but I went narrower because they were rubbing slightly, but I think I've made a mistake and should have got 255/40/18?
Guest Garfy
Not for long with those on he won't be :eyebrows:
Never skimp on tryes, too risky :rolleyes:
thats very easy to say, but when I bought the tyres I had a puncher, had just lost my job, and they were right on the legal limit, so no one would have repaired the tyre, so, it was cheap tyres or no car, I opted for cheap tyres, luckily my freind came to the rescue with a repair kit, that actually worked, but the tyres were already here by then.
Since then however, I've started my own business and things are looking very good :)
If you are experiencing vague handling you need to get your suspension bushes checked for terminal wear and play, a 4 wheel alignment if they are OK, and the shocks checked as well. Tyres won't play that much of a part in gammy handling, maybe some tramlining if their wear pattern and pressures are incorrect.
-Ian
Guest Garfy
-Ian
I've checked all the bushes, nothing seems worn, and shocks are also good, I've got it book in to wheels in motion tomorrow, hopefully that will sort it.
Have you had it up on a ramp and gone at it levering like mad with a breaker bar to see if stuff moves? Because anything else just isn't trying :)
-Ian
Guest david
i have Federal 595's on they were on the car when i got it and i thought i don't want budget ones i want some good ones but i think if they are a good recognised budget Tyre they are just as good as moor expensive ones u just pay for the name yes they may be a Little better say round a track but for every day use they are fine. i have driven supras withe pirelli p zero and on every day roads cant tell the difference.i am very happy with the federal 595 and would have them again. :D
Guest Garfy
-Ian
I'll do that when its on the ramp getting the geo done tomorrow, thanks :)
Guest Garfy
Thank you, I have actually spoken to the guy who will be doing the geo, his exact words were, "they are ok, not the best tyres in the world, but far from the worst"
I'll report back tomorrow :)
265/35/ on the rear will give you the same roalling radius as the 235/40s on the front slighlty wider than the 255s so id recomment going with those on the back, khumo supras are a good tyre to go for value for money wise they are a medium compound so they wear pretty well without losing to mutch performance
Edited by dr_jekyll (see edit history)
conclusion
there is nothing wrong with these tyres, the problem was partly me, and partly badly set up suspension, its all sorted now though, Garfy happy :)
Guest The_Scorpion
just my opinion here, a great car like a supra derserves much better tyres then This!!!!
the tyres are the contact with the road and extremely iomportant and 1 of the very last things you schould ever try to save money on!
tyres can make and break a car!
