Dave F Posted August 4, 2008 Share Posted August 4, 2008 Need to get hold of a couple of dipped beam connectors loom side as mine are corroded. Time is an issue so are there any normal cars that I can cut them from in your average breakers. Cheers Dave Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 4, 2008 Share Posted August 4, 2008 I'd get the new connectors from Mr T. Very cheap. Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted August 4, 2008 Share Posted August 4, 2008 you just need someone to donate there unused spare loom from the HID kits from the group buy, the connectors are the same, you just need to cut the wires, solder and shrink tube them Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 4, 2008 Share Posted August 4, 2008 Bizarrey I just noticed this weekend that one of mine is corroded too. Can you actually buy the connector kits from Toyota? Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 5, 2008 Share Posted August 5, 2008 Yep, you just buy the metal strip connectors for the lights which go inside the plastic housings. Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 5, 2008 Share Posted August 5, 2008 Yep, you just buy the metal strip connectors for the lights which go inside the plastic housings. Ah. My housing is fubar'd as well. I need the whole assembly. Quote Link to comment Share on other sites More sharing options...
Dave F Posted August 5, 2008 Author Share Posted August 5, 2008 Same as mate Quote Link to comment Share on other sites More sharing options...
Dave F Posted August 5, 2008 Author Share Posted August 5, 2008 MR T says £23 for a pair sir:D Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 5, 2008 Share Posted August 5, 2008 MR T says £23 for a pair sir:D Of complete connectors? If so, cool. I'm away from my EPC. Do you know the part numbers? Quote Link to comment Share on other sites More sharing options...
Dave F Posted August 5, 2008 Author Share Posted August 5, 2008 Did'nt get the part number as I was told they would have to be ordered in. Went to a local breakers and what did I see... A Celica with all connectors in place £5 pound for all four:) Quote Link to comment Share on other sites More sharing options...
