gavin.starr Posted August 4, 2008 Share Posted August 4, 2008 my car has started whining when i turn left and right either stationary or moving is it likeley to be my pump or rack is on its way out. any help would be appreciated as i would like to catch it now before anything breaks thanks in advance gavin Quote Link to comment Share on other sites More sharing options...
heckler Posted August 4, 2008 Share Posted August 4, 2008 just bleed the PAS system Quote Link to comment Share on other sites More sharing options...
Nic Posted August 4, 2008 Share Posted August 4, 2008 Check power steering fluid level, it is either low fluid and air in the system or pump on it's way out. To bleed remove the cap and whilst stationary with the engine running turn the steering lock to lock a few times, this should get rid of any trapped air, you may need to top up fluid again after. If the fluid is low, then you may have a slight leak somewhere, check around the pump and the steering rack for leaking fluid. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 4, 2008 Share Posted August 4, 2008 Also check your crank pulley for signs of it degrading. A creaking sound when stationary is normal when the crank pulley starts to go. Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted August 4, 2008 Author Share Posted August 4, 2008 just bleed the PAS system im not clued up on power steering as every car i have previously owned hasnt had it what does PAS stand for thanks gavin Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted August 4, 2008 Author Share Posted August 4, 2008 Check power steering fluid level, it is either low fluid and air in the system or pump on it's way out. To bleed remove the cap and whilst stationary with the engine running turn the steering lock to lock a few times, this should get rid of any trapped air, you may need to top up fluid again after. If the fluid is low, then you may have a slight leak somewhere, check around the pump and the steering rack for leaking fluid. ill give this a go at dinner and see what happens ive got some spare fluid at home to top it up if need be. cheers nic Quote Link to comment Share on other sites More sharing options...
SimonT Posted August 4, 2008 Share Posted August 4, 2008 what does PAS stand for Power Assisted Steering. I didnt realise this was such a common problem with these as i have seen quite a few separate threads on this including my own!! Quote Link to comment Share on other sites More sharing options...
heckler Posted August 4, 2008 Share Posted August 4, 2008 Check power steering fluid level, it is either low fluid and air in the system or pump on it's way out. To bleed remove the cap and whilst stationary with the engine running turn the steering lock to lock a few times, this should get rid of any trapped air, you may need to top up fluid again after. If the fluid is low, then you may have a slight leak somewhere, check around the pump and the steering rack for leaking fluid. nic, to bleed the system the wheels need to be off the ground, and turn the wheel with engine off, then put on the ground, do the same with engine running Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 4, 2008 Share Posted August 4, 2008 nic, to bleed the system the wheels need to be off the ground, and turn the wheel with engine off, then put on the ground, do the same with engine running I followed this instruction and after several goes the noise stopped Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted August 4, 2008 Author Share Posted August 4, 2008 i didnt think that PAS was going to be something so simple i feel a bit dumb now for asking that Power Assisted Steering so simple my head must be scrambled. ill leave it until i get home from work then if i need to raise the car off the ground as i havent got any jacks at work hope it sorts the problem as its not a nice noise cheers for the help fellas gav Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted August 5, 2008 Share Posted August 5, 2008 I have a leak in mine with the same symptoms. If you bleed the system, top up the fluid then bleed again you won't have any problems. But I would check for a leak as well. Bottom of the PS pump is common - the seals go on them. Good luck mate Quote Link to comment Share on other sites More sharing options...
