marc_p Posted August 2, 2008 Share Posted August 2, 2008 Ok , so basically I have removed the 22mm bolt holding the pulley on but cant actually remove the pulley, it's almost like it's welded itself on, is there a special way to remove the pulley? Cheers Marc p.s. I did search first but couldn't find anything on this issue. Quote Link to comment Share on other sites More sharing options...
Jake Posted August 2, 2008 Share Posted August 2, 2008 (edited) I made a Heath Robinson style puller from two bolts and a flat piece of metal. Drilled two holes in the metal and put each bolt through a hole and then into the pulley. Then wind out the pulley bolt against the flat metal, which pulls the pulley off the crank. Edited August 2, 2008 by Jake (see edit history) Quote Link to comment Share on other sites More sharing options...
marc_p Posted August 2, 2008 Author Share Posted August 2, 2008 Cheers for the reply Jake, unfortunately I have already tried this using a socket in the middle to push against, but no joy. Quote Link to comment Share on other sites More sharing options...
Jake Posted August 2, 2008 Share Posted August 2, 2008 I guess you're going to need a proper puller then mate. You can hire them. Quote Link to comment Share on other sites More sharing options...
marc_p Posted August 2, 2008 Author Share Posted August 2, 2008 Phew, well I just tried it again (with a much stronger bar that didn't bend) and then whacked it like billy joe with a small hammer and eventually it came off. Cheers for the help anyway Jake, at least I knew I was doing the right thing. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted August 2, 2008 Share Posted August 2, 2008 Phew, well I just tried it again (with a much stronger bar that didn't bend) and then whacked it like billy joe with a small hammer and eventually it came off. Cheers for the help anyway Jake, at least I knew I was doing the right thing. glad you got it off mate, am going to be doing mine next weekend:rolleyes: Quote Link to comment Share on other sites More sharing options...
marc_p Posted August 2, 2008 Author Share Posted August 2, 2008 glad you got it off mate, am going to be doing mine next weekend:rolleyes: Just keep telling yourself 'it will come off' and eventually you'll get there Anyway it's all back together now so looking forward to driving it as i've only had it 4 days in the last month. Quote Link to comment Share on other sites More sharing options...
Rob Posted August 2, 2008 Share Posted August 2, 2008 Doh, I has a puller already made, I could have lent it to you. Quote Link to comment Share on other sites More sharing options...
