123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 right i have just tried the cable that Heckler sent me and i still have the exact same problem..... As soon as i plug the cable in the laptop recognises it straight away and a bubble pops up in the bottom corner of the screen saying EMB cable connected and then the software also says online, even though i havent even plugged it into the EMB main unit it still says on line. I thought this was a little strange (me thinking online means when your plugged into the main unit.) I can not think what to do next it is annoying as hell. IT STILL WONT CORRESPOND EITHER!!!! no movement on the loading bar.:( Any ideas Simon???? Quote Link to comment Share on other sites More sharing options...
heckler Posted August 12, 2008 Share Posted August 12, 2008 right i have just tried the cable that Heckler sent me and i still have the exact same problem..... As soon as i plug the cable in the laptop recognises it straight away and a bubble pops up in the bottom corner of the screen saying EMB cable connected and then the software also says online, even though i havent even plugged it into the EMB main unit it still says on line. I thought this was a little strange (me thinking online means when your plugged into the main unit.) I can not think what to do next it is annoying as hell. IT STILL WONT CORRESPOND EITHER!!!! no movement on the loading bar.:( Any ideas Simon???? did you install the driver i emailed to you? Quote Link to comment Share on other sites More sharing options...
heckler Posted August 12, 2008 Share Posted August 12, 2008 i think the bigger end of the cable goes to the emb... Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 did you install the driver i emailed to you? yes i have installed the driver and that works fine, i have set the emb software to com5 and the com port which the cable is on to com5, i have got it the right way round, as you said it does only pick the cable up one way.... every thing seems to be spot on apart from the fact it wond correspond, i also tried to update the main unit to 1.39 and it said there was a connection failure.... maybe it is the software i have i dont think it is genuine, it is version 1.11 which is the first one i think, can anybody tell me what colour the disk is, ie is it black, white, blue:) Quote Link to comment Share on other sites More sharing options...
heckler Posted August 12, 2008 Share Posted August 12, 2008 yes i have installed the driver and that works fine, i have set the emb software to com5 and the com port which the cable is on to com5, i have got it the right way round, as you said it does only pick the cable up one way.... every thing seems to be spot on apart from the fact it wond correspond, i also tried to update the main unit to 1.39 and it said there was a connection failure.... maybe it is the software i have i dont think it is genuine, it is version 1.11 which is the first one i think, can anybody tell me what colour the disk is, ie is it black, white, blue:) there is a software update available aswell... Quote Link to comment Share on other sites More sharing options...
steve spedd Posted August 12, 2008 Share Posted August 12, 2008 Speak to Kieren 1234, he bought a cable that works. dont think it was that much money... Quote Link to comment Share on other sites More sharing options...
heckler Posted August 12, 2008 Share Posted August 12, 2008 Speak to Kieren 1234, he bought a cable that works. dont think it was that much money... the cable works as its mine works fine on my emanage Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 there is a software update available aswell... yes i did do the software update but i then did a fresh reinstall of the software. The only version i can update this software to is 1.13 and that would need the 1.39 firmware for the emb unit, but i cant update the unit as it just says connection failure when i click update and give it the option update info..... so what next??? there is some thing i am missing but i cant put my finger on it!!!!! i hate EMB :( can anybody send me the new version in a zipped file or something..... the actual software i mean not the update..... the cable definatley works as i said before as soon as i plug it in it says emb cable then the software comes from offline to online. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 12, 2008 Share Posted August 12, 2008 I would be inclined to see if i could borrow somebody's laptop and try that, and if it does the same then its down to a software or cable problem. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 I would be inclined to see if i could borrow somebody's laptop and try that, and if it does the same then its down to a software or cable problem. yes i think i am going to do that next.... i think laptop can be eliminated by borrowing someone else's, could it really be software it think it is genuine, pic below.... and cable is proven as been working as it is hecklers and he has used it on his. what i dont get is i am doing everything by the book on the install of the software through to the cable. I am then doing it in the order it says, plugging the cable into the laptop then into the emb unit, then turn the ignition on, then opening the software up. the lights are lit up on the emb so that is on??? another quick question is the green light on the unit ment to stay on when you turn the ignition off:) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 12, 2008 Share Posted August 12, 2008 Green light should go out after a few seconds when you turn off the ignition, I usually open the software, plug in and then turn the ign on, if i have had any problems i have just unplugged/replugged the lead and it says communicating with main unit, (ultimate) Another option is to try your laptop with another unit, and then I'm afraid it could be a faulty unit. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 (edited) Green light should go out after a few seconds when you turn off the ignition, I usually open the software, plug in and then turn the ign on, if i have had any problems i have just unplugged/replugged the lead and it says communicating with main unit, (ultimate) Another option is to try your laptop with another unit, and then I'm afraid it could be a faulty unit. the unit is from ryan g on this forum, i wouldnt think he would sell on faulty goods, unless it has gone like that in transit. i am going to try the other laptop route first then, well i dont know what then, dont know anyone with a emb near by i can try it on. i have done the jumper setting inside as per the guide on page one of this thread and i have also done all the other setting as per the guide, that shouldnt make a difference anyway should it? Edited August 12, 2008 by 123tom123tom (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 12, 2008 Share Posted August 12, 2008 I wasn't suggesting it was sold faulty, but they can be damaged by bad connections/shorts etc, fingers crossed that another laptop works, it could even be i config problem, if the com port is being used or is reserved for another application it could be something like that, although you usually get some error message, but not always;) No jumpers and setup will not affect communication. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 12, 2008 Author Share Posted August 12, 2008 I wasn't suggesting it was sold faulty, but they can be damaged by bad connections/shorts etc, fingers crossed that another laptop works, it could even be i config problem, if the com port is being used or is reserved for another application it could be something like that, although you usually get some error message, but not always;) No jumpers and setup will not affect communication. i wonder why the emanage software says it is online then i'm confused to hell..... i set the com ports up as per the software instruction, going into the device manager - ports - finding the EMB cable port - right clicked it - advanced - set it to com port 5 on the laptop. Then i went into the EMB software - communication - com 5 seleted, was offline at this point then when i selected com5 the E logo in the top corner started flashing green and the bottom corner flashed up online. would it not corrispond if there was nothing on the main unit? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 14, 2008 Author Share Posted August 14, 2008 right i have just tried another laptop with the same result as before. all com ports are the same the cable definatley works, tried on hecklers emb.... could the wiring of the unit cause problems, i personally didnt wire this unit but the emb unit active light stays on green even when the key isnt in the ignition. Any more ideas guys or am i gunna have to buy a new emb. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 14, 2008 Share Posted August 14, 2008 Its obviously got a permanent live, which it shouldn't have, whether it will affect it in the way that you describe i don't know, it does make me wonder what other wiring faults it may have though, get somebody who knows what there doing to go through the wiring, and if the unit is damaged then i would replace it with an Ultimate. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 16, 2008 Author Share Posted August 16, 2008 Its obviously got a permanent live, which it shouldn't have, whether it will affect it in the way that you describe i don't know, it does make me wonder what other wiring faults it may have though, get somebody who knows what there doing to go through the wiring, and if the unit is damaged then i would replace it with an Ultimate. i dont know who wired the harness, it was some one on this forum, if i did get a ultimate ecu would it use the same harness etc... Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 16, 2008 Share Posted August 16, 2008 Yes EMU uses the same harness, but has an extra plug/harness that you would need to add. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 16, 2008 Share Posted August 16, 2008 Tom, where abouts do you live. Do you know Rotherham?? My mate, Ricky does all my mapping and has mapped SteveSpedds supra too and they are absolutely spot on, the afr's are perfect throughout the whole rev range and it only cost £100 for him to do it. Yours may cost more as you will need ignition map doing whereas i didnt. If you want his number then drop me a PM and i will send it to you. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 29, 2008 Author Share Posted August 29, 2008 hi there people, just a quick question again about this emb.... i have the injector wires wired into the field harness, but was wondering if i need the ignition wires also wiring in. if you look at the first page on this thread you will see the injectors are wired, but there is no ignition timing wires. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 29, 2008 Share Posted August 29, 2008 You don't need them wired in, it just means you can't adjust the ignition timing edit - are the ignition wires on the harness cut or just spliced in? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 29, 2008 Author Share Posted August 29, 2008 You don't need them wired in, it just means you can't adjust the ignition timing edit - are the ignition wires on the harness cut or just spliced in? it is just the injector wires that are plumed into the field harness at the minute. the ignition ones are just in a box in the cuboard what am asking is, does the ignition timing need to be done when going single or will it be ok as it is with just the injector wires plumbed in.:);) Quote Link to comment Share on other sites More sharing options...
Homer Posted August 29, 2008 Share Posted August 29, 2008 Ah right. Well you don't *need* ingition timing adjustment to get it started and running, but it is highly recommended. I remember a lot of timing adjustment on my old map in the TT switch-over area and at the high end. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted August 29, 2008 Share Posted August 29, 2008 Tom, where abouts do you live. Do you know Rotherham?? My mate, Ricky does all my mapping and has mapped SteveSpedds supra too and they are absolutely spot on, the afr's are perfect throughout the whole rev range and it only cost £100 for him to do it. Yours may cost more as you will need ignition map doing whereas i didnt. If you want his number then drop me a PM and i will send it to you. Ricky who? I didn't know anyone who maps EMB or EMU around here? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted August 29, 2008 Author Share Posted August 29, 2008 Ricky who? I didn't know anyone who maps EMB or EMU around here? apparently a good mapper round our area, mapped a few supra's, might just give him ago as there are no others in our area. he also does road mapping which is better according to a number of threads that i have read.... Quote Link to comment Share on other sites More sharing options...
