MaveriK Posted August 2, 2008 Share Posted August 2, 2008 Greetings, Should the BOV go off between gear changes on an autobox Quote Link to comment Share on other sites More sharing options...
CardiffSupra Posted August 2, 2008 Share Posted August 2, 2008 I can hear it go off just a little on mine, But only for a split second. Quote Link to comment Share on other sites More sharing options...
supra_si Posted August 2, 2008 Share Posted August 2, 2008 it can do but mine usually goes off when i release the accelerator, mine s does go off if im around the 6k rpm range and change gears Quote Link to comment Share on other sites More sharing options...
tomgeer Posted August 2, 2008 Share Posted August 2, 2008 it can do but mine usually goes off when i release the accelerator, mine s does go off if im around the 6k rpm range and change gears yes, the same as mine, it only goes off during gear changes at higher revs. Quote Link to comment Share on other sites More sharing options...
Ric Posted August 2, 2008 Share Posted August 2, 2008 if your accelerating super hard, if not, usually not Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted August 2, 2008 Share Posted August 2, 2008 at full tilt (read foot to the floor) the traction control cuts back a little on the gas to allow a smoother transition between gears, i small chirp my be heard then but not a full tsshhhh sound the manual give unless you lift off your self;), however if the stock tc is disabled in some way you just get a harsh gear change and no tsshhhh;) Quote Link to comment Share on other sites More sharing options...
hadyn Posted August 2, 2008 Share Posted August 2, 2008 Yes Quote Link to comment Share on other sites More sharing options...
