Brake bleeding mare
colsoop
Right i can't seem to sort this out.
My car has uk brakes (converted from j specs)
I purchased a low miles Brake master cylinder and fitted it to my car.
Filled it with fluid and proceeded to bleed the brakes via a air fed trigger operated bleeder kit.
After doing all 4 corners rear left / right - front left / right the pedal is still going all the way to the floor, (when foot pressure is applied)
I then bled the brake master cylinder to be sure it wasn't air trapped in there and again still to the floor, no resistance at all !
When i depress the brake pedal i get a humm noise as it goes through its range of travel to the floor.
Any suggestions or help appreciated.
Is the Master cuylinder fubared ?
The other problem is i took my old one apart to check out what it was like so i can't swap them back over again to check :rolleyes:
Edited by colsoop (see edit history)
If youve got ABS then brake bleeding is a mare, once you get air into the pump its a beeatch to get out, and it only takes a small amout of air to cause probs. Can I ask why you changed your master cylinder?
I changed it because i saw a low mileage one come up for sale and having bled the brakes i still got a spongy pedal. I thought the MBC maybe a little tired (98k miles on mine) so a swap to a low mileage unit was the plan.
I have a couple more diagnostic tests to try to see if i can locate where the issue is as bleeding with engine running still hasn't helped.
