pa06has Posted August 1, 2008 Share Posted August 1, 2008 when you cut into the main wires, do i need to splice into them or just cut them? Paul Quote Link to comment Share on other sites More sharing options...
heckler Posted August 1, 2008 Share Posted August 1, 2008 you need to cut the wires, and connect them to the resistor pack Quote Link to comment Share on other sites More sharing options...
pa06has Posted August 1, 2008 Author Share Posted August 1, 2008 thanks matey! Quote Link to comment Share on other sites More sharing options...
pa06has Posted August 4, 2008 Author Share Posted August 4, 2008 Having problems with this! the mechanic fixing this have never needed to put one of these in and is having problems with it! can someone explain this in simple terms how to fit a resistor pack! hopefully i can just print off the text and give it to him to follow! Thanks Quote Link to comment Share on other sites More sharing options...
heckler Posted August 4, 2008 Share Posted August 4, 2008 Having problems with this! the mechanic fixing this have never needed to put one of these in and is having problems with it! can someone explain this in simple terms how to fit a resistor pack! hopefully i can just print off the text and give it to him to follow! Thanks http://www.internetwork.org.uk/Injectors/Injectors.htm - step 18 - FAQ's are fun! Quote Link to comment Share on other sites More sharing options...
pa06has Posted August 5, 2008 Author Share Posted August 5, 2008 spot on matey! thanks Quote Link to comment Share on other sites More sharing options...
heckler Posted August 5, 2008 Share Posted August 5, 2008 spot on matey! thanks easy isnt it - I've done quite a few now Quote Link to comment Share on other sites More sharing options...
Guest Trevlin Posted August 14, 2008 Share Posted August 14, 2008 what about for a lexus IS300 ? Quote Link to comment Share on other sites More sharing options...
