Batmax Posted August 13, 2008 Author Share Posted August 13, 2008 what could be these : Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2008 Share Posted August 13, 2008 Probably the drink, it's all gone blurry. What are we supposed to be looking at here? Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Share Posted August 13, 2008 From the video it *sounds* like its running incredibly rich. I had the same issue a while back when the ECU couldn't adjust the injector lag. Either way, that sounds like a massive overfuel. Link to comment Share on other sites More sharing options...
Kev.O Posted August 13, 2008 Share Posted August 13, 2008 Probably the drink, it's all gone blurry. What are we supposed to be looking at here? Have you looked here Chris Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 13, 2008 Share Posted August 13, 2008 Sounds like a bad overfuel! Get the car over to the UK (or Japan) and get it looked at by a pro tuner. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2008 Share Posted August 13, 2008 Have you looked here Chris I have, damned depressing, I was out of there like a rat from a drain pipe with a terrier on it. :0 Link to comment Share on other sites More sharing options...
Kev.O Posted August 13, 2008 Share Posted August 13, 2008 i have, damned depressing, i was out of there like a rat from a drain pipe with a terrier on it. :0 Link to comment Share on other sites More sharing options...
colsoop Posted August 14, 2008 Share Posted August 14, 2008 They should, and do glow bright red under full boost. You need to tell us WHEN it glows red hot. It's possible the ignition timing could be too retarded, or the fuel mixture wrong, if it glows red at other times. Faults like those are engine killers. What ecu, who mapped it, and how? What AFR readings? What EGT readings? Where are the thermal barriers? Without those things WILL melt, even if the engine's running perfectly!! Check ignition timing, check cam timing, adjust as required. Have it remapped in other words. Cant see your map but going on comment made, i would get somebody competent to remap it before you kill the engine big time if you haven't already caused damage. You NEED to get this mapped properly. The map you posted is configured for a 3bar gm sensor, not a 3.5bar aem, the fueling and ignition curves are not be suitable for a GT67 turbo. Wht AFR gauge are you using? luck has nothing to do with it, you have not tuned it/got it tuned correctly Plugs look mega rich (though only indicates recent exposure' date=' maybe at idle?)[/quote'] From the video it *sounds* like its running incredibly rich. I had the same issue a while back when the ECU couldn't adjust the injector lag. Either way, that sounds like a massive overfuel. I have quoted the advice in this thread, just so you can see the theme thats going here. Take the advice fella. People are only helpful for so long Link to comment Share on other sites More sharing options...
bolarbag Posted August 14, 2008 Share Posted August 14, 2008 I have quoted the advice in this thread, just so you can see the theme thats going here. Take the advice fella. People are only helpful for so long very true, I think you should honestly sell the car and buy an oem turbo car and leave it at that If you dont understand the need for the above then your last option is to have a guide who does, failing that your on to plums:rolleyes: Link to comment Share on other sites More sharing options...
Terminator Posted August 14, 2008 Share Posted August 14, 2008 Some words in english are hard understand to me, my english is bad could you explain bether and is possible I do any test to check if are somethink broken, please, thanks. Do not turn the engine on again until you have a fully qualified mapper to start it for you. Link to comment Share on other sites More sharing options...
Batmax Posted August 14, 2008 Author Share Posted August 14, 2008 I have to put new plugs. Now check these pics of my turbo is Dbb ? Link to comment Share on other sites More sharing options...
dandan Posted August 14, 2008 Share Posted August 14, 2008 Now check these pics of my turbo is Dbb ? No Link to comment Share on other sites More sharing options...
SteveR Posted August 14, 2008 Share Posted August 14, 2008 Don't worry about the turbo being DBB or not or whether it's water cooled or not. Get your priorities sorted out (get the mapping sorted!!) your car is going to destroy itself! Link to comment Share on other sites More sharing options...
Batmax Posted August 14, 2008 Author Share Posted August 14, 2008 About the mapping Ryan G come map my car, in these moment the supra is Stop, I just notice yesterday he is with fuel execess maybe I have to change the plugs before mapping right ? Link to comment Share on other sites More sharing options...
Batmax Posted August 14, 2008 Author Share Posted August 14, 2008 (edited) ... Edited August 14, 2008 by Batmax (see edit history) Link to comment Share on other sites More sharing options...
SteveR Posted August 14, 2008 Share Posted August 14, 2008 Probably the drink, it's all gone blurry. What are we supposed to be looking at here? You need to click the pics Chris, and it'll open up the video behind them ... If you're trying to get Ryan.G's attention, you'd be better sending him a Private Message mate. Link to comment Share on other sites More sharing options...
Batmax Posted August 14, 2008 Author Share Posted August 14, 2008 You need to click the pics Chris, and it'll open up the video behind them If you're trying to get Ryan.G's attention, you'd be better sending him a Private Message mate. Thanks for the helping my friend I have spoke with him Link to comment Share on other sites More sharing options...
Batmax Posted August 15, 2008 Author Share Posted August 15, 2008 After change the plugs the Supra starts ok: Now I have these question, check in these pics the piece of metal on the diagnostic box do you have these to ? How I read errors once I have now Aem Ems installed ? Link to comment Share on other sites More sharing options...
supra matt Posted August 16, 2008 Share Posted August 16, 2008 (edited) You cant read error codes with the AEM as it dose not support that feature , To be oncied Mate as has been said time and time again leave your car alone as you don't seem to have a clue what your doing! And are going to cause yourself a lot of Gareth if you keep trying to tune it with out the proper tools , Your best bet is pm Ryan G and ask him to sell you a base map to get it running safe then take it somewhere to get full map . Edited August 16, 2008 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
Homer Posted August 16, 2008 Share Posted August 16, 2008 This is ridiculous Why do you bother posting here if nothing any one recommends is taken onboard? Nice exhaust gasket leak there too... Goodbye to yet another 2JZ-GTE! Link to comment Share on other sites More sharing options...
SteveR Posted August 16, 2008 Share Posted August 16, 2008 That doesn't sound clever at all. Maybe it's just the exhaust leak but it made me cringe listening to it. Link to comment Share on other sites More sharing options...
Batmax Posted August 16, 2008 Author Share Posted August 16, 2008 (edited) I think the noise you are talk is belt, why you say that, I have heard your advices so that the car is not stopped this goes. I am not sure that this all in the car as well as the ryan here comes the car should be ok you understand what I mean I'm not trying to map it Edited August 16, 2008 by Batmax (see edit history) Link to comment Share on other sites More sharing options...
Batmax Posted August 20, 2008 Author Share Posted August 20, 2008 Don't worry about the turbo being DBB or not or whether it's water cooled or not. Get your priorities sorted out (get the mapping sorted!!) your car is going to destroy itself! I pay Dbb thay why I ask Link to comment Share on other sites More sharing options...
dandan Posted August 20, 2008 Share Posted August 20, 2008 Who did you buy from? Link to comment Share on other sites More sharing options...
Batmax Posted August 20, 2008 Author Share Posted August 20, 2008 PowerhouseRacing a lot of produts Joe say it´s Dbb... Link to comment Share on other sites More sharing options...
