Chris Wilson Posted July 31, 2008 Share Posted July 31, 2008 (edited) Nicely modded 1uz engine. 534 BHP 330 ft/lbs torque, dry sumped on Motec management and throttle bodies. http://www.chriswilson.tv/Erol_lexus_manifolds.jpg Edited July 31, 2008 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Bobbeh Posted July 31, 2008 Share Posted July 31, 2008 Bet that sounds nice Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 For 120,000 dollars plus shipping you can find out http://www.race-cars.com/carsales/reynard/1217389977/1217389977ss.htm Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 Added a second pic I have found, this must be it in build in Oz, as the empty transaxle case is from a sequential box Reynard F3000. I will find out more on these engines, they look like they have had some proper development work done on them. Builder is Erol Richardson in Oz, photographed with the engine.. Link to comment Share on other sites More sharing options...
johnny g Posted July 31, 2008 Share Posted July 31, 2008 How much would it cost just to get a 1UZ to that level, or even say, 500bhp? Link to comment Share on other sites More sharing options...
bolarbag Posted July 31, 2008 Share Posted July 31, 2008 Would that even fit in a JZA80 Chassis? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 £20 to 25 K with the ECU and loom? Depends what's inside it, which I intend to find out. If it's on a stock crank, with decent rods and pistons, with head work, cams and porting, and a dry sump it may be within those figures, if it has a custom lightweight steel crank it may go over. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 Would that even fit in a JZA80 Chassis? Easily, if it fits up the back end of an F3000. It would sit very low, too, dry sumped. Link to comment Share on other sites More sharing options...
garethr Posted July 31, 2008 Share Posted July 31, 2008 (edited) I think Erol Richardson is a moderator on the Lextreme forum, username rms. EDIT: He is. This is his thread on the engine. In the members' section. http://www.lextreme.com/forums/showthread.php?t=8431 Not quite stock! Rev limiter is set at 9200. Rods, pistons, 12.5 comp, cams, cam buckets, springs, 36mm inlet, 32mm exh, raised ports, 50mm slide plate ITBs, Siemens piezo crystal injectors, exhaust, dry sump, Motec M800, Motec 8 channel cdi, etc, etc. Running 98 octane pump fuel. Port roof raised 4mm, floor is untouched. Cams are 330 deg, .430" lift. Our cam profile is race only and could not be used on the street, idle is around 1500/1800 rpm - 6"dia flywheel and 5"dia clutch doesn't help, not lumpy or 'cammy' just no grunt under 4500. Rebuild about every 2500km, crack test, brgs, rings, valve springs, timing belt etc. About the same as a V8 Supercar engine. Edited July 31, 2008 by garethr (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted July 31, 2008 Share Posted July 31, 2008 Something for Homers project Link to comment Share on other sites More sharing options...
garethr Posted July 31, 2008 Share Posted July 31, 2008 Dyno graph Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 Here you go: http://www.race-cars.com/engsales/other/1200038700/1200038700ss.htm Link to comment Share on other sites More sharing options...
Wez Posted July 31, 2008 Share Posted July 31, 2008 Dyno graph Could do with smoothing out but the looks of it. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2008 Author Share Posted July 31, 2008 Nice torque curve! Link to comment Share on other sites More sharing options...
