Jevansio's complete stock to single thread
jevansio
  • Replies 91
There are no pics of the actual block & head build as they were pre-built items supplied by Michel, so we'll jump to the assembly of parts onto the block & head.
1st the inlet manifold, what a PITA it is keeping that & the cam covers shiny, sometimes wish I hadn't gone for the bling look :D:
The next couple of pics show the exhaust setup I went for. The manifold is the Sound Performance copy of the HKS T4 manifold. The wastegate is the HKS 60mm. The downpipe again is Sound Performance, but I opted for the wastegate to be fed back into the exhaust to reduce noise.
This pic shows the downpipe heatwrapped with the EGT & O2 sensors in. I eventually moved the EGT probe pre-turbo as the reading I was getting was about 200 deg below the pre-turbo reading & hence pretty useless.
Next step was to drop the engine back in.
Bits & pieces in the engine bay were painted black to tidy them up. The original radiator remained in until the new Koyo radiator turned up.
Then the engine went back in:
Right I'm off for a couple of pints :D, will update more later
The next step was to continue bolting more of the anciliaries on. I went for a cheap set of bling pulleys initially, bad move, they shredded a Kevlar Auxillary Pulley within a week. So I went back to the stock pulleys, I'll prolly get a set of Unorthadox Pulleys later.
Next the FMIC was hooked up. You can see the blue oil cooler to cool the engine oil as well as the silver power steering cooler (just) on the right. The PS was rather large & was swapped for a slightly smaller unit (but it mounted in the same place).
The BOV is a Teal item, I love it, awesome sound & looks pretty cool too (esp as you can see it through the front bumper vent).
My cone filter was mounted where the old SMIC was located. It was great for drawing in cool air, but eventually the filter was covered in crap from the road.
I've since moved it to the engine bay & will be building a cold air box along the lines of the one Rich (UK-Rich) made.
These are the final shots of the car after the single install. I'll do a summary of the events I went through getting the car mapped as some of you may recall, it wasn't plain sailing. I've also got the brake & suspension setup to cover and I should be nearly uptodate :)
