Jevansio's complete stock to single thread
jevansio
  • Replies 91
Next step was to replace my crumbling SMIC.
I decided to go with an XS-Power FMIC (which has remained on the car until very recently :D). Again this was purchased from Michel, it was £500, but came with an original Greddy 3-Row hardpipe kit, coolant relocation bottle & free fitting from Michel :)
The core is the same 12" x 24" x 4" dimensions as a Greddy 3-Row, although the endtank design is nowhere near as good. TBH it served a purpose at BPU level, but I should really have moved upto a quality item sooner after going single.
I do believe the ducting which I made (I'll come to that later) helped tremendously in the efficience of this core
PS ignore the dump valve, this pic was taken at the time of my single install.
Anyway the exhaust I chose was the HKS Ti Racing, I wanted something that sounded mint & I was bowled over by this video/sound clip.
back in the day I wanted this exhaust on my tt but I didnt realise going single would completely change the sound of the supra, I think I would have been fairly dissapointed after spending that money and expecting that sound on a TT!
good thread btw! :)
  • 3 weeks later...
So the car was now fully BPU & I was enjoying it immensely, so much in fact that after a month the clutch started to slip.
I had already had the "single" seed planted in my head by this point so I decided to get a clutch that would suit my BPU & future needs.
I went for the RPS Stage 3 from MVP & Cyn-R-G flywheel, I took MVP's advice & also changed the throw out bearing, pilot bearing, flywheel bolts, & snap ring. In total with shipping & taxes it came to approx £900.
With plans for a single build in full swing I decided to go for a full set of defi's to keep an eye on things. Problem being the ones I wanted (BF in blue as they were smoked when off & had the startup/shutdown sequence) only came in 60mm.
I didn't want gauges all over the a-pillar & passenger airbag space, so I decided to do a custom mount for all the gauges where the stereo goes, this involved losing the stereo headunit for the time being.
I started by positioning where I thought the gauges looked best in Photoshop:
Then used a wooden frame with holes to hold the gauges secured to the back of the original dash plate, I decided 6 would not fit below so moved the boost gauge into the left hand side air vent:
I then used fibre glass & filler to build the curve at the bottom back up then many hours of smoothing & filling & spraying with primer to get it back to the original shape:
The end result once sprayed matt black, you can see the optional Defi indicator light on the steering column which lights when any of the gauges pass a preset warning level:
Here is a short YT video showing the startup, throttle blip & shutdown sequence of the gauges:
6k3xq1FNVpA
Edited by jevansio (see edit history)
Still the best dash of any Supra I've been in.
Made you're not selling it now Jay.
Many thanks mate, much appreciated :thumbs:
Where about did you get the heater & gear knob surrounds from? Dash looks great, nice & classy :)
They're all MVP aluminium rings, bought in a group buy ages ago, around my birthday I think, I was rather drunk that night :D
  • 2 weeks later...
Wow – Job well done – Nice dash – I am impressed. Have you relocated the stereo somewhere?
I did have it located in the rear view mirror, but it's all ripped out now ;)
Nice writeup mate. Looking forward to the next chapter. ;)
Posted via Mobile Device
Cheers Surj, will hopefully get more time to update this this week, got loads on my hands at the mo
  • 4 months later...
Right, lets get this thread back on the go.
The next step for me was a single turbo installation. Michel was offering a full single install with a built engine & head for £8k. I decided that I may aswell go the whole 9 yards and get the lot done.
The work was carried out by Storm Racing. The following is a breakdown of the work done/parts fitted (grey items were parts already purchased/fitted):
Built Engine
  • Eagle H-Beam Rods
  • Aries Pistons 86.5mm Coated
  • ARP Main Bolts
  • ARP Head Bolts
  • Clevite Bearings
  • Balanced Crank
  • Engine Honed & Decked
  • Modified Oil Channels
  • New Oil Pump
  • New Water Pump
  • PE Timing Belt & Fan Belt
  • BL Crank Pulley
  • Polsihed Fan Belt Pulleys
Built Head
  • Greddy Polished Inlet Manifold
  • Q45 Polished Throttle Body
  • HKS Cams (264 In/Ex)
  • AEM Cam Gears
  • Ferrea Valvetrain
  • Ported Head
Turbo & Exhaust
  • Precision GT4088R 0.68 A/R
  • HKS Cone Filter (located in stock SMIC area)
  • SP Tubular Manifold - Heat Wrapped
  • SP Downpipe & Midpipe 3"
  • HKS 60mm Wastegate (No Screamer)
  • HKS Titanium Racing 4" Exhaust
  • Tial Dump Valve
  • Turbo Blanket
Electronics
  • Blitz DSBC @ around 1.4 BAR
  • AEM ECU with 3.5 BAR MAP Sensor
  • AEM Wideband O2 Kit
  • Defi BF Blue Full Gauge Setup with Indicator including Oil Temp, Water Temp, EGT, Fuel Press, Oil Press & Boost
  • HKS DLI
  • Slimline Gel Battery with relocation kit
Cooling
  • XS Power 4" FMIC with Hardpipes
  • Koyo Radiator with Blitz 1.3 BAR Cap
  • AAP Twin Fans Polished
  • TRD Thermostat
  • Mocul Oil Cooler with Relocation Kit
  • Power Steering Cooler
Fuel
  • Precision 880cc Injectors
  • Walbro Twin Fuel Pumps
  • HKS Fuel Rail
  • Fuel Lines/Fittings
  • Aeromotive Filter
  • Aeromotive FPR
Drivetrain
  • RPS Stage 3 6 Puck Clutch
  • RPS Cyn-R-G Segmented Flywheel
Interior
  • Momo Handbrake & Leather Gaitor
  • Momo Gearknob & Leather Gaitor
  • Custom Dash Mount for 6 Defi's
