gaz1 Posted July 29, 2008 Share Posted July 29, 2008 i have a big oil leak coming from the oil feed/drain pipe the one that goes into the bottom of the turbo, the leak has been there sometime and noticed its dripping straight onto the manifold. The problem i have is when i tighten the fitting it makes the fitting(not pipe) touch the manifold, i know thats not ideal but would it be ok i have cut my fingers getting the compressor side of the exaust off (with my minimun amount of tools) Quote Link to comment Share on other sites More sharing options...
Pig Posted July 29, 2008 Share Posted July 29, 2008 I wouldnt want things touching TBH mate. With the temps they get up to and the movement that occurs under boost. I think you need to have the fitting taken off, more lock tight put on and re-fitted. Please bear in mine that i dont have an ounce of technical knowledge but enjoy type things on the forum. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 29, 2008 Author Share Posted July 29, 2008 I wouldnt want things touching TBH mate. With the temps they get up to and the movement that occurs under boost. I think you need to have the fitting taken off, more lock tight put on and re-fitted. Please bear in mine that i dont have an ounce of technical knowledge but enjoy type things on the forum. yeah i kinda thought so although its the big nut not the hose, but i know what you mean Quote Link to comment Share on other sites More sharing options...
