ballsdeep Posted July 29, 2008 Share Posted July 29, 2008 ok here goes, fitted some new pads and discs to a 1999 golf mk4 1.4, everything went smoothly untill i came to put her 18" alloys back on, once they were on i couldnt move the car and i could hear a scraping noise.. so whipped them off again and found the metal plate on brake pad was touching the inside of her alloys and dug a groove all the way round! which cracked the brake pad, so i returned the pads and was replaced with another brand but they are still the same thickness and still touch the wheels when fitted!! i then tried the stock steal wheel and its fine no problem attall, my question is after all this is... should there be spacers on when fitting bigger alloy wheels??? could that be the problem??? hope someone can help... Quote Link to comment Share on other sites More sharing options...
Guest mcnsongs Posted January 23, 2009 Share Posted January 23, 2009 i have noticed problems when braking hard.. so i had the brakes changed... both the disc and the pads.. however.. the wheels locked up.. but the mechanic saw the problem and started grinding the sides of the brake so the wheels would move.. it has worked.. but there is still noise.. so.. i will be taking it back monday so he can grind further.. unless there is a different solution..?? different brake pads or something? any help will be apreciated.. thanks Quote Link to comment Share on other sites More sharing options...
RobUK Posted January 23, 2009 Share Posted January 23, 2009 Wrong Forum?? LOL Quote Link to comment Share on other sites More sharing options...
rich_supra Posted January 23, 2009 Share Posted January 23, 2009 (edited) oops Edited January 23, 2009 by rich_supra re read thread - typed wrong stuff. MOD please remove (see edit history) Quote Link to comment Share on other sites More sharing options...
