Cant fit 2nd decat...
hadyn
Bought this second hand 2nd decat off TDI on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=230269846606&ssPageName=STRK:MEWA:PIC&ih=013
Tried to fit it yesterday and unfortunately the hole on the flange at the front of the decat appears to be too small to accept the 1st cat. Pipe lines up fine but just wont pull together due to the difference in diameter between the decat and 1st cat holes. The 1st cat has a lip which seems to foul the decat.
Any ideas? Am i doing something wrong? I think the front has been modified (as shown in the ad) and therefore doesnt fit...
ive had a few like that in the past...you have to chop the bit off the 1st cat to allow the 2nd one to butt up to it...its about 1.5cm roughly but grind/cut it away and it will butt up ok...
Had to do that with mine, strange that.
Not sure, how easy would it be to lop off the end of the 2nd cat, bolt it into position finger tight in place at both ends (obviously they wont be joined). Then you could bring it into position with a set of extra hands and tack it into place. Remove the 2nd cat and weld properly.
This is the response from Mark at TDI, when I informed him about the decat not fitting:
"Hi, it should fit perfectly (it came off a JDM TT). Pleas take another look at it. You can send it back if you want but we can't refund your postage costs. Best regards, Mark"
I've replied saying that I think the decat may have originally been fitted to a tt with a 1st decat with flat flange.
I await his response.
Do I have to remove the 1st cat to grind the flange off? Im worried it will be a nightmare in situ. Whats the best way to get rid of it? Hacksaw?
You can do it in situ but will be a bit trickier, angle grinder is your best bet but a hacksaw will do :)
Hmm strange, my second decat (2nd hand ebay one) doesn't line up right and i need to get an angle grinder on the top edge of the flange too
Interesting that. Perhaps a lot of these pipes are only designed to mate to 1st decat pipes with flat flanges?
Just had a message back from TDI stating that they wont refund postage, but that it should fit perfectly as it came off a JDM TT and should fit with or without the 1st cat.
Do you think I've been a bit of dumbass in fitting it?
