JamieP Posted July 29, 2008 Author Share Posted July 29, 2008 What about this set up Jamie? http://www.mkivsupra.net/vbb/showthread.php?t=121701 I want a bolt on kit designed for the car:) Link to comment Share on other sites More sharing options...
Guest Nicholas Posted July 29, 2008 Share Posted July 29, 2008 Stop tech all the way, I have the front kit same as Paul Whiffin I think and they are Monsters Link to comment Share on other sites More sharing options...
Luxluc Posted July 29, 2008 Share Posted July 29, 2008 Stop tech all the way, I have the front kit same as Paul Whiffin I think and they are Monsters Are thos the 355mm 4 pots you have on ?? Link to comment Share on other sites More sharing options...
Guest Nicholas Posted July 29, 2008 Share Posted July 29, 2008 Are thos the 355mm 4 pots you have on ?? I have them yes, not fitted yet as I am mid single conversion but I do know the car that won the handling course at texas 2k8 had them Link to comment Share on other sites More sharing options...
Luxluc Posted July 29, 2008 Share Posted July 29, 2008 Great ... I begin to see clear on what to go for Link to comment Share on other sites More sharing options...
dk_supra Posted July 29, 2008 Share Posted July 29, 2008 JBT setup and the price is very good. As for stopping power i cannot compare them to anything but my buddies 997 tt, with the pccb setup. Several braking from 330km/hr, and they could care less. Of course I have the 380mm 6 piston front and 360mm 4 piston rear. As for bolt on, it couldn´t be more bolt on. You just need 19's. Call Arnout to hook you up, easier to get it from the Netherlands. http://www.suprasport.nl Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2008 Author Share Posted July 29, 2008 JBT setup and the price is very good. As for stopping power i cannot compare them to anything but my buddies 997 tt, with the pccb setup. Several braking from 330km/hr, and they could care less. Of course I have the 380mm 6 piston front and 360mm 4 piston rear. As for bolt on, it couldn´t be more bolt on. You just need 19's. Call Arnout to hook you up, easier to get it from the Netherlands. http://www.suprasport.nl Funny you mention them as i looked at them last night, look good, ill send him an email. http://www.suprasport.nl/Supra_MK_IV/Brakes/JBT_brake_kit.html Link to comment Share on other sites More sharing options...
Luxluc Posted July 29, 2008 Share Posted July 29, 2008 Did you set some criterias for yourself ... like disc diameter, number of pots and so on? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 29, 2008 Share Posted July 29, 2008 Just got my Stoptech's out of the box and really do look the nuts, very nicely made, lets hope they perform as well as they look. Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2008 Author Share Posted July 29, 2008 Did you set some criterias for yourself ... like disc diameter, number of pots and so on? I hear big is best:d Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 29, 2008 Share Posted July 29, 2008 You'll like the Stoptech's then Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2008 Author Share Posted July 29, 2008 Ill have a look at them and the kads when i come over, few other bits i want aswell so will talk to you then. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 29, 2008 Share Posted July 29, 2008 Okee dokee Link to comment Share on other sites More sharing options...
dk_supra Posted July 29, 2008 Share Posted July 29, 2008 From what I tried, Stoptech discs crack all the time, and the pads that they give are junk out of the box. The calipers are fine, no worries there. Brembos are awesome but you have to get the monobloc setup which are big big big bucks. Grex kits are Brembos Endless are perfect, they should be the standard to be compared as they are unreal. But they have an issue, they have too much of a stopping power, and you will be locking the tyres before you get used to them (thank god for the abs) Rotoras are very good, but I hate how the floating rotors make noises when they warm up. You think they will explode for real. Other kits like Kad, Hispec,D2 etc. I will not even discuss, they are very low budget, good for what they are, but not for a high speed vehicle. And now we come to my choice of the JBTs. Well I was afraid in the beginning before I got the kits. Stopping power is incredible, repeatability excellent especially on high speed chases, looks they look as any big brake kit (everybody likes it), quality of calipers and flex of them I don't know. But for sure they are not Brembos monobloc, but i cannot see any issues with them. Please take into consideration that the car is a street car and not a time attack car. So I cannot judge for this kind of scenarios. If I was going to build a time attack ride then brembos with ONLY slotted rotors would be the choice. On the rears of the JBT i had to file the bracket about 2mm on the corner on the bottom of each side because it was a clearance issue with the ball joint if my memory serves me well. And I used the spacers of 1/4 mm that they had for the caliper mounting, in order to clear the rotor from the caliper. BUt of course the brackets of the calipers are big like they are going to hold a ship while breaking. The fronts got in as they were out of the box. No noise from the brakes at all, and no issues with braking when cold or hot. I hope I helped a bit. Cheers Dimitri Link to comment Share on other sites More sharing options...
dk_supra Posted July 29, 2008 Share Posted July 29, 2008 http://www.supras.nl/ scroll a little bit down and you will see the kit I bought as well. cheers Link to comment Share on other sites More sharing options...
STU_3LTR_TT Posted July 29, 2008 Share Posted July 29, 2008 hi jamiep,have a look at nengun performance,i purchased grex/greedy,4 pot rear 6 pot front,they look very well made,but not had chance to use them yet,as my car is miles away from been finished. Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2008 Author Share Posted July 29, 2008 How much was they please? Link to comment Share on other sites More sharing options...
STU_3LTR_TT Posted July 30, 2008 Share Posted July 30, 2008 How much was they please? around £2400 delivered. Link to comment Share on other sites More sharing options...
JamieP Posted July 30, 2008 Author Share Posted July 30, 2008 Thats not bad, what size are the fronts? Link to comment Share on other sites More sharing options...
Gaz Walker Posted July 30, 2008 Share Posted July 30, 2008 Other kits like Kad, Hispec,D2 etc. I will not even discuss, they are very low budget, good for what they are, but not for a high speed vehicle. The man speaketh the truth Link to comment Share on other sites More sharing options...
JamieP Posted July 30, 2008 Author Share Posted July 30, 2008 What brakes do you have on the envy car gaz? Link to comment Share on other sites More sharing options...
RobSheffield Posted July 30, 2008 Share Posted July 30, 2008 Brembo 14" with monoblock 6 pot front and 4 pot rears You know it makes sense Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 30, 2008 Share Posted July 30, 2008 You need to be looking at cars/people that are using them for track use, if they are ok for that, they'll never give you problems on the road. Link to comment Share on other sites More sharing options...
JamieP Posted July 30, 2008 Author Share Posted July 30, 2008 Brembo 14" with monoblock 6 pot front and 4 pot rears You know it makes sense Big bucks id expect, Im waiting for prices from all over the place. Good point on the track cars, are both Steve and Ben running Kads? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 30, 2008 Share Posted July 30, 2008 Indeed they are. I can however supply AP, Brembo, Stoptech, Endless, whatever you need basically. Link to comment Share on other sites More sharing options...
