snow button
Guest RichyRZ-S
Guest RichyRZ-S
Hi guys,
I ve bought a vvti tiptronic RZ-s, I cant get the snow button to work, also the clock isnt working. Is this likely to be a fuse or is there something else wrong ? anyone help?
As already suggested, the first thing to check would be that those items are plugged in behind the dash. It's possible that when your car had a speedo converter fitted, someone forgot to reconnect something.
There's a great page here that shows you how to remove the dash (very easy):
http://www.internetwork.org.uk/Dash%20Conversion/Instructions.htm
The dash on your VVTi looks slightly different to the pictures shown but the principles are exactly the same (your centre section - surrounding the instrument dials - is not screwed in place, it's just a push fit; the left section - the big one - does have one screw at the top corner; the right section - with the ignition key - also has one screw at the top corner). Just one caveat - DO NOT be tempted turn on the ignition (to test, say) with the dash panels removed (the top one can cause problems with your air-bag warning light).
Edited by spartan (see edit history)
