Guest RichyRZ-S Posted July 28, 2008 Share Posted July 28, 2008 Hi guys, I ve bought a vvti tiptronic RZ-s, I cant get the snow button to work, also the clock isnt working. Is this likely to be a fuse or is there something else wrong ? anyone help? Quote Link to comment Share on other sites More sharing options...
Ark Posted July 28, 2008 Share Posted July 28, 2008 Have you checked the fuses yet? Have you taken the dashboard off to make sure those units are plugged in? Quote Link to comment Share on other sites More sharing options...
spartan Posted July 28, 2008 Share Posted July 28, 2008 (edited) As already suggested, the first thing to check would be that those items are plugged in behind the dash. It's possible that when your car had a speedo converter fitted, someone forgot to reconnect something. There's a great page here that shows you how to remove the dash (very easy): http://www.internetwork.org.uk/Dash%20Conversion/Instructions.htm The dash on your VVTi looks slightly different to the pictures shown but the principles are exactly the same (your centre section - surrounding the instrument dials - is not screwed in place, it's just a push fit; the left section - the big one - does have one screw at the top corner; the right section - with the ignition key - also has one screw at the top corner). Just one caveat - DO NOT be tempted turn on the ignition (to test, say) with the dash panels removed (the top one can cause problems with your air-bag warning light). Edited July 28, 2008 by spartan (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest RichyRZ-S Posted July 28, 2008 Share Posted July 28, 2008 Thanks for replying guys, very helpful, thanks alot ! cheers ! Quote Link to comment Share on other sites More sharing options...
