absz Posted July 27, 2008 Share Posted July 27, 2008 (edited) I have connected my Aem uego gauge to the Aem ems (white 0-5v output wire to pin 48) with the o2 sensor disconnected i'am getting 2.35volts on pin 48 which it should but the reading on the ems data is showing 00.05volts and it stays at that voltage no matter what i do, have calibrated the o2 gain but makes no difference. anyone know what i'm doing wrong? Edited August 2, 2008 by absz (see edit history) Link to comment Share on other sites More sharing options...
Muffleman Posted July 27, 2008 Share Posted July 27, 2008 Have you chosen the AEM gauge in sensor setup ? Setup\Sensors\Oxygen Sensor\O2 Sensor #2\O2 Sensor #2 Wizard and choose AEM Gauge. I've chosen sensor #2 as its pin 48 Link to comment Share on other sites More sharing options...
absz Posted July 27, 2008 Author Share Posted July 27, 2008 I have set both sensor#1 and #2 to aem gauge type. i do not have a wire on pin 47 hence using pin 48. Link to comment Share on other sites More sharing options...
absz Posted August 2, 2008 Author Share Posted August 2, 2008 Right problem solved with the 02 reading the ems was configured to use pin 47 and my signal wire was on pin 48. Moving on to the next problem attached is a screen shot of the display with just the ignition On engine not running, it seems that the ems is thinking that the engine is on load hence over fuelling. I still have the standard map sensor fitted. any input please guys Link to comment Share on other sites More sharing options...
spiderpigcity Posted August 3, 2008 Share Posted August 3, 2008 Right problem solved with the 02 reading the ems was configured to use pin 47 and my signal wire was on pin 48. Moving on to the next problem attached is a screen shot of the display with just the ignition On engine not running, it seems that the ems is thinking that the engine is on load hence over fuelling. I still have the standard map sensor fitted. any input please guys mine doing same, but running 3.5bar map sensor. just ticks over like a bag of sh*t. i wouldnt attempt to map it yourself. ryan charges very reasonable fees and he knows his stuff. let him do it. Link to comment Share on other sites More sharing options...
absz Posted August 3, 2008 Author Share Posted August 3, 2008 mine doing same, but running 3.5bar map sensor. just ticks over like a bag of sh*t. i wouldnt attempt to map it yourself. ryan charges very reasonable fees and he knows his stuff. let him do it. I will not be mapping it just need to get it in a running state so i can drive it to him:D Link to comment Share on other sites More sharing options...
Ryan.G Posted August 3, 2008 Share Posted August 3, 2008 Hey Mate If you click on Fuel on the toolbar and then T Fuel it will bring up the fuel table which will also show a PARAMETERS window on the left. On the engine load parameters what are you seeing? To select the correct map sensor you need to go to SETUP - SENSORS - MANIFOLD PRESSURE SENSOR - MAP SENSOR WIZARD Then select Toyota ALL is you have the stock map sensor or 3.5bar if you have the aem 3.5 sensor. But its not that easy to make it driveable as need to make sure the correct battery offsets are set for the injectors then the microset bit was correct. So what i would suggest if pop me a pm with full spec abs and will sort you a map to get to me at the dyno. Ryan Link to comment Share on other sites More sharing options...
absz Posted August 3, 2008 Author Share Posted August 3, 2008 Hey Mate If you click on Fuel on the toolbar and then T Fuel it will bring up the fuel table which will also show a PARAMETERS window on the left. On the engine load parameters what are you seeing? To select the correct map sensor you need to go to SETUP - SENSORS - MANIFOLD PRESSURE SENSOR - MAP SENSOR WIZARD Then select Toyota ALL is you have the stock map sensor or 3.5bar if you have the aem 3.5 sensor. But its not that easy to make it driveable as need to make sure the correct battery offsets are set for the injectors then the microset bit was correct. So what i would suggest if pop me a pm with full spec abs and will sort you a map to get to me at the dyno. Ryan cheers mate will do Link to comment Share on other sites More sharing options...
