marc_p Posted July 25, 2008 Share Posted July 25, 2008 Hi, Had a bit of a problem last night, the ring that the belt goes around fell off the crank pulley:blink: and it looks like it was probably slipping a very very slight amount on the crank pulley. Is it alright to put the ring back on with a little bit of sealant as the ring looks to be in perfectly good condition as it fell off in the pub car park when I started the car and the belt is also fine, I think the belt just came a bit loose and allowed the ring to come off, the thing is I really need the car for tommorrow, I am alright to do this? Cheers Marc Quote Link to comment Share on other sites More sharing options...
Jay_vr6 Posted July 25, 2008 Share Posted July 25, 2008 is that a joke? dude I think you need a whole new crank pulley bodging the old one is madness. although someone with more knowledge will be along shortly Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted July 25, 2008 Share Posted July 25, 2008 You need a new crank pulley, you cant fix this with sealant I am afraid Quote Link to comment Share on other sites More sharing options...
Havard Posted July 25, 2008 Share Posted July 25, 2008 New crank pulley I'm afraid....!! I got one in June £203 from Toyota...... H. Quote Link to comment Share on other sites More sharing options...
marc_p Posted July 25, 2008 Author Share Posted July 25, 2008 You need a new crank pulley, you cant fix this with sealant I am afraid ah well, cheers, i'll go get a new one tommorrow, would a place like Andrew Page stock them? Quote Link to comment Share on other sites More sharing options...
marc_p Posted July 25, 2008 Author Share Posted July 25, 2008 I'm guessing it's a rubber damperd one then. Quote Link to comment Share on other sites More sharing options...
Havard Posted July 25, 2008 Share Posted July 25, 2008 I'm guessing it's a rubber damperd one then. Oh yes!! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 25, 2008 Share Posted July 25, 2008 You may need a new crankshaft as well if the remaining hub of the pulley is loose on the nose of the crank. This is because it may have chewed up the keyway in the crank and worn the nose of the shaft undersize. I have now become something of an expert at salvaging these though, so if your attempt with sealant fails 9it will, in time, possibly spectacularly), let me know Quote Link to comment Share on other sites More sharing options...
