03 Mondeo air con leaking.. advice req..
MrRalphMan
Hi,
Just found out after Kwik-Fit regassed the car that I have a leak. Seems to be coming from the lower right of the car looking at the front of the car.
KF cannot fix, but will regas for free once it's repaired.
Anyone know someone good in Essex to get this repaired?
Cheers,
Paul.
Hi,
Cheers,
Paul.
Hi dont know how big your leak is but halford do a A/C system sealant for small leaks know 3 people now who have used it with successful results.
Might be a cheaper alternative.
Chris
Chris
Leak was big enough to loose all cooling in a day, 2 tops.
Don't know if that counts as a big leak? Hissing is pretty loud though.. :(
I would say if it took all day to lose its gas then its prob not a very big leak and loud hissing would also suggest quite a small hole/leak as their wouldnt be enough gas in the system to sustain a loud hissing noise through a big hole for that amount of time.
Hope that makes sense to you im not the best at explaining things like that but i would still try the halfords route if you dont want to go to the expense of getting a dealer/garage to fix it.
Cheers chris
Edited by chris burford (see edit history)
