A 4.7L 2UZ NA Engine Swap into a MKIV NA.
All going a bit slow at the moment. I've been figuring out how to install my racing clutch and bearing setup. I'm waiting on parts from Steve at Toyota Oxford which he's just told me should arrive later today. Then, I can start building the clutch onto the engine and taking all the necessary measurements for a custom bearing retainer to be fabricated. I'll be posting my progress in my project thread.
Here - http://www.mkivsupra.net/vbb/showthread.php?t=159441&highlight=2uzfe
  • 1 year later...
  • Replies 182
Still here, just busy building motors and producing firearms parts. :)
Making these:
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs534.snc3/30316_102904536424850_100001159110179_26718_7094883_n.jpg
And these mega HP pistons:
FSR Billet construction
94mm bore
.927" pin bore
9310 oversized pin
Contoured crown to match the cylinder head
2.5mm oversized valve reliefs
Ceramic crown coating
Side skirt coating
Reinforced crown
5.4L specific C/H
Thanks!
Eric
Edited by cowboy bebop (see edit history)
  • 6 years later...
