Wez Posted August 1, 2008 Share Posted August 1, 2008 excellent. DO you know what size banjo is required? Quote Link to comment Share on other sites More sharing options...
heckler Posted August 1, 2008 Author Share Posted August 1, 2008 Where did you get the Banjo from? its off one of the links that dimitri posted earler.. its down as a fitment kit for a cossie - £9.99! (see post 32) Quote Link to comment Share on other sites More sharing options...
dk_supra Posted August 2, 2008 Share Posted August 2, 2008 i think it´s a 12mm banjo, but get the kit so you can be sure about it. Quote Link to comment Share on other sites More sharing options...
heckler Posted August 9, 2008 Author Share Posted August 9, 2008 ok, took longer than planned... final article. no pretty, just functional. http://www.internetwork.org.uk/pump/pump6.jpg Quote Link to comment Share on other sites More sharing options...
AndyT Posted August 9, 2008 Share Posted August 9, 2008 ok, took longer than planned... final article. no pretty, just functional. http://www.internetwork.org.uk/pump/pump6.jpg Good work Si. I thought that shiny regulator you fitted would've been suitable. Thinking further I conclude I'm a div. Quote Link to comment Share on other sites More sharing options...
heckler Posted August 9, 2008 Author Share Posted August 9, 2008 Good work Si. I thought that shiny regulator you fitted would've been suitable. Thinking further I conclude I'm a div. ahhh, the shiney regulator has a different job to do! Quote Link to comment Share on other sites More sharing options...
b_have Posted August 10, 2008 Share Posted August 10, 2008 I'm still a little confused over the check valve. Isn't there a straight fitting available, with a check valve to avoid using a bendy exit pipe? If that pipe isn't preformed, it could kink. (If it does, byebye engine ) Quote Link to comment Share on other sites More sharing options...
heckler Posted August 10, 2008 Author Share Posted August 10, 2008 I'm still a little confused over the check valve. Isn't there a straight fitting available' date=' with a check valve to avoid using a bendy exit pipe? If that pipe isn't preformed, it could kink. (If it does, byebye engine )[/quote'] there probably is, but the check valve which comes with the pump is for a banjo bolt fitting. I'm not sure if there would be enough clearance between the top of the pump and hanger if you put an "inline" check valve in with fittings, unless you put it externally... Quote Link to comment Share on other sites More sharing options...
paul mac Posted October 29, 2008 Share Posted October 29, 2008 bit of a resurrection but could someone explain exactly why the NRV has to be used with the banjo as i am confused Quote Link to comment Share on other sites More sharing options...
Wez Posted October 29, 2008 Share Posted October 29, 2008 bit of a resurrection but could someone explain exactly why the NRV has to be used with the banjo as i am confused I have removed it and gone with a straight through fitting as some others have, I was advised to do this by many people I trust. Time will tell I guess. Quote Link to comment Share on other sites More sharing options...
paul mac Posted October 29, 2008 Share Posted October 29, 2008 I have removed it and gone with a straight through fitting as some others have, I was advised to do this by many people I trust. Time will tell I guess. thanks Wez, i was originally going with twin pumps but keep having recuring nightmares over one failing so for me this looks the way to go Quote Link to comment Share on other sites More sharing options...
paul mac Posted November 7, 2008 Share Posted November 7, 2008 (edited) been doing some research on this non return/check valve issue and found this site http://www.furiousperformance.com.au/store/index.php?main_page=product_info&products_id=421 the main point i gleaned from this is ~ When the engine is shut off the fuel pressure left between the Pump and Regulator will need to escape. The quickest exit is back through the pump if there is know valve fitted. This can harm the pumps life span as large back pressures can put strain on the pumps internal parts. It is better for the fuel to escape through the regulator as that is what it is made for. Now i cant verify this as gospell but going off what Dimitri said it does sound reasonable looking at the check valve/banjo arrangement on the Bosch it does look quite a flow restriction, i did think about ditching it but felt uncomfortable with this as Mr Bosch obviously put it there for a reason and kinking a flexible hose around out of site in the fuel tank looks a recipe for disaster aswell, looking at the Oz site above it would appear they are using http://www.speedflowshop.co.uk/valves-check-breather-pressure-realease--onoff-173-c.asp which are made in the UK and available to buy here, for £20 i think i am going to use one Edited November 7, 2008 by paul mac forgot somet (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted November 7, 2008 Share Posted November 7, 2008 Nice find Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted January 3, 2009 Share Posted January 3, 2009 Paul, is it this one..? http://www.speedflowshop.co.uk/check-valve--08-jic-male-ports-610-08-1191-p.asp Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted January 3, 2009 Share Posted January 3, 2009 Or drill it out? Quote Link to comment Share on other sites More sharing options...
paul mac Posted January 4, 2009 Share Posted January 4, 2009 Paul, is it this one..? http://www.speedflowshop.co.uk/check-valve--08-jic-male-ports-610-08-1191-p.asp yes, however on further checking, the only problem is the Bosch thread is M12 x 1.5, which speedflowshop (UK) dont list so i'm getting one from Aus, i never thought to contact the UK peeps but it seems a little odd both companys trade the same gear and claim to make it themselves so it might be worth contacting the UK peeps to see if they do the right thread Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted January 4, 2009 Share Posted January 4, 2009 After i posted up, i found the exact same one that is on that Furious site above, but $20 cheaper. Part number 612-08 ISTR. Quote Link to comment Share on other sites More sharing options...
paul mac Posted January 4, 2009 Share Posted January 4, 2009 After i posted up, i found the exact same one that is on that Furious site above, but $20 cheaper. Part number 612-08 ISTR. wheres that from Rob Quote Link to comment Share on other sites More sharing options...
Steve Posted January 4, 2009 Share Posted January 4, 2009 wheres that from Rob http://www.speedflowstore.com/products.asp?CatID=CARBY%20-and-%20FUEL%20SYS I have emailed them to get a price for 2 of them. Can change it to 3 if you are after one Quote Link to comment Share on other sites More sharing options...
b_have Posted January 4, 2009 Share Posted January 4, 2009 I wonder if the check valve compromises flow? Quote Link to comment Share on other sites More sharing options...
Steve Posted January 4, 2009 Share Posted January 4, 2009 I wonder if the check valve compromises flow? If you read this info on it, they say it doesnt. Just depends whether you beleive them or not http://www.furiousperformance.com.au/store/index.php?main_page=product_info&products_id=421 Quote Link to comment Share on other sites More sharing options...
dandan Posted January 4, 2009 Share Posted January 4, 2009 wheres that from Rob http://www.speedflowstore.com/products.asp?CatID=CARBY%20-and-%20FUEL%20SYS I have emailed them to get a price for 2 of them. Can change it to 3 if you are after one Paul - wherever you get yours from, can you still get me a Dash 6 one please. Cheers Dan Quote Link to comment Share on other sites More sharing options...
