Bosch 044 v walbro size comparison
heckler
  • Replies 71
Posted Images
ok, just a few pics from todays effort.
http://www.internetwork.org.uk/pump/pump1.jpg
a bare hanger.
http://www.internetwork.org.uk/pump/pump2.jpg
Fuel pipe cut short to accomodate the some-what taller pump
http://www.internetwork.org.uk/pump/pump3.jpg
The end "tab" trimmed to allow the filter adaptor to sit in appox correct position
http://www.internetwork.org.uk/pump/pump4.jpg
Pump fitted with heavy duty cable ties. I have put this in the tank and the pump sits about 10mm to low, so tommorow I'll fix that!
I was wondering about that. Couldn't you measure the distance from the bottom of the stock pump to the top of the hanger and make sure the new one lines up to the same spot?
i based it on the height of the filter from the top, so due to the size/location of the filter and adaptor, I ended up cutting the bottom of the hanger off! Fits like a glove!
