markybhoy86 Posted July 23, 2008 Share Posted July 23, 2008 Have a clunking noise from the rear of the car, both sides, somtimes it sounds a bit like somthings loose like a slapping noise lol if that makes sense. i've checked everythings tight, i changed the droplinks today and still it happens. my next thought it could be the bump stop from when the previous owner has changed the suspension. it happens mostly over uneven road how do i check this easily, this will be on the driveway not a ramp ? if its not that what else could i try? cheers M Link to comment Share on other sites More sharing options...
SupraShaun Posted July 23, 2008 Share Posted July 23, 2008 It could also be your boot Link to comment Share on other sites More sharing options...
johnd-mkiv Posted July 23, 2008 Share Posted July 23, 2008 Boot stops, exhaust poss banging on the bumper, my upper wishbones were gone on my other supra that made it clunk to more so when reversing Link to comment Share on other sites More sharing options...
Nic Posted July 23, 2008 Share Posted July 23, 2008 Have you checked all the suspension and sub frame bolts? These are a common reason for clunking noises. Link to comment Share on other sites More sharing options...
markybhoy86 Posted July 24, 2008 Author Share Posted July 24, 2008 the exhaust is solid i tryed that, subframe seems solid to me i tryed that also, none of the bushes look badly worn either. i read a post on this about clunking etc and someone mentioned the bump stops being fitted the wrong way, seemed to make sense since the springs have been changed and it clunks both sides? the boot does have the common speaking noise but i dont think its that which is causing it. M Link to comment Share on other sites More sharing options...
markybhoy86 Posted July 24, 2008 Author Share Posted July 24, 2008 how do i remove the suspension to get into the bump stop?? step-by-step would be helpful cheers Link to comment Share on other sites More sharing options...
