EssexBoy Posted July 23, 2008 Share Posted July 23, 2008 Looking at buying a MINES ECU for my car and I know the engine is a 2JZ-GTE however the bloke im buying the ecu off only has 2JZ-GT stamped on the ecu. I said this was for a non turbo model but he said no its for a turbo model for some reason on the ecu they leave the E off for some reason. Is this true or is he just blagging me so I buy it? thanks Link to comment Share on other sites More sharing options...
Thorin Posted July 23, 2008 Share Posted July 23, 2008 2JZ-GE is the non turbo engine. Link to comment Share on other sites More sharing options...
Jake Posted July 23, 2008 Share Posted July 23, 2008 The seller is correct; GTE ECUs only have "2JZ-GT" on them. Perfectly normal. By the way, Non turbo Supras are GE not GT Link to comment Share on other sites More sharing options...
Matt H Posted July 23, 2008 Share Posted July 23, 2008 I thought GTE was for cruise control Link to comment Share on other sites More sharing options...
EssexBoy Posted July 23, 2008 Author Share Posted July 23, 2008 Thanks for your help guys much appreciated!. So are you saying that if I buy a MINES ECU with 2JZ-GT on it then it is definately for the twin turbo model. Someone advised me that for the delimit part to work it has to have a wire connected from the ecu to the TRAC ecu is this correct? Is it easy to do?there is no wire comming out of the MINES ecu to do this like the Blitz. Any help? does anyone have a MINES ecu here??? Link to comment Share on other sites More sharing options...
PJ Posted July 23, 2008 Share Posted July 23, 2008 On the Blitz Access ECU for the Aristo, there is a blue wire that runs out of it that connects to a relay, when the vehicles reaches 112mph voltage is sent down the wire that activates the relay and cuts power to the TRAC ECU. Cutting power to the TRAC ECU delimits the car. You can pull the fuse on the TRAC ECU to prove that point. You will need to have something like this on any ECU you put in the Aristo as it's the TRAC ECU that governs the speed cut. Personally I would just pull the fuse anyway as the standard traction control on the Aristo is awful. Link to comment Share on other sites More sharing options...
Jake Posted July 23, 2008 Share Posted July 23, 2008 Pulling the TRAC fuse doesn't delimit a j-spec Supra. Link to comment Share on other sites More sharing options...
PJ Posted July 23, 2008 Share Posted July 23, 2008 Pulling the TRAC fuse doesn't delimit a j-spec Supra. That's alright seeing as he has an Aristo. Link to comment Share on other sites More sharing options...
Alex Posted July 23, 2008 Share Posted July 23, 2008 The Mines ECU is plug and play delimiting... Link to comment Share on other sites More sharing options...
Guest banjo_bob Posted July 23, 2008 Share Posted July 23, 2008 Are we talking about an Aristo or Supra?? (Supra I guess seeing as it's a Supra forum??)the MINES isn't plug and play delimit on the Aristo (mk1 anyway) Link to comment Share on other sites More sharing options...
dandan Posted July 23, 2008 Share Posted July 23, 2008 Great ECU. How much are you paying if you don't mind me asking? Link to comment Share on other sites More sharing options...
PJ Posted July 23, 2008 Share Posted July 23, 2008 Are we talking about an Aristo or Supra?? (Supra I guess seeing as it's a Supra forum??)the MINES isn't plug and play delimit on the Aristo (mk1 anyway) Essexboy has a mk1 Aristo. Link to comment Share on other sites More sharing options...
EssexBoy Posted July 23, 2008 Author Share Posted July 23, 2008 Peejay thanks for pointing that out. Sorry guys I should of said the Aristo. Im confused one person is saying the MINES is a plug in and play for the delimit and someone else is saying it isnt. It has been pointed out that a wire does need to go from the ecu to the TRAC ecu as thats what controls the delimit. The Blitz Access ecu has a blue wire that connects to this ecu but the mines has no wire running from it. Why is that? does it do the same as the Blitz? Blitz and MINES ecus are very cheap from the US if you can find them. Link to comment Share on other sites More sharing options...
