Google Maps, anyway to plot a shape using the lon/lat values?
MrRalphMan
Check out:
http://code.google.com/apis/maps/documentation/overlays.html
GPolyline - Drawing Poly lines into a layer may be what you are after?
e.g. from the above:
var polyline = new GPolyline([
new GLatLng(37.4419, -122.1419),
new GLatLng(37.4519, -122.1519)
], "#ff0000", 10);
map.addOverlay(polyline);
Edit:
Actually just about any of the drawing stuff below that point looks cool... might start playing with that myself :D:D:D
Cheers,
Si.
Thanks, looks like it's exactly what I needed, worked in work, but at home I don't see the overlay.. That's on two PC's...
Can anyone else see the overlay here?
If so can you place the following code in a HTML file and open it in your browser.. Then maybe attach a screen shot of the map and overlay?
Cheers..
Paul.
   Google Maps JavaScript API Example: Simple Polygon
               type="text/javascript">
   <br />
    function initialize() {<br />
      if (GBrowserIsCompatible()) {<br />
        var map = new GMap2(document.getElementById("map_canvas"));<br />
        map.setCenter(new GLatLng(51.59363, 0.429238), 20);<br />
        map.addControl(new GSmallMapControl());<br />
        GEvent.addListener(map, "click", function(overlay,latlng) {<br />
       	  var polygon = new GPolygon([<br />
            new GLatLng(51.59363, 0.429238),<br />
            new GLatLng(51.60295, 0.42461),<br />
            new GLatLng(51.59428, 0.418858),<br />
            new GLatLng(51.59363, 0.429238)<br />
		  ], "#f33f00", 5, 1, "#ff0000", 0.2);<br />
		  map.addOverlay(polygon);<br />
        });<br />
      }<br />
    }   <br />
  <br />
Cheers..
Paul.
   <br />
        });<br />
      }<br />
    }   <br />
  <br />
I had to zoom out a bit to find where the polygon had ... gone ;) I am sure there is a joke in there somewhere.
http://www.istslice.co.uk/pics/a08654/mapsnapshot.png
Edit: p.s. I meant to mention MacOS 10.5.4 using Firefox 3.0.1.
Edit2: p.p.s Looks to work on Firefox 3.0.1 on WindowsXP and also IE 7.
