TurboBrett Posted July 21, 2008 Share Posted July 21, 2008 its a kit made by Asetek, possibly the best at the time of purchase some parts are missing or need replacing whats in the box: *dual fan radiator, and 2 x 120mm fans in as new condition now there clean:d (not even a single bent fin:)) *cpu block for AMD 939 pin processor, i think it fits the 940 (am2) aswell but i cannot find any confirmation *gpu block, it is a universal block and has been fitted to 3 of my cards but i dont know what i will definitely fit *motherboard block aswell *all fittings for the radiator, fans and blocks all parts have compression fittings attached, it is very quick to fit and install, it will need pipes and a pump unfortunately my pump died but these are not expensive there is a salvaged length of pipe in the box but it only for the pipe size and type thats printed onto it ( 6.5mm id 10mm od PU (poly urethane?)) the blocks could do with a good clean before being used again but all can be stripped down this dropped my idle cpu temps (compared to stock H/S/F)by close to 20degC and flat out temps by over 10degC and the grapics card temps by well over 30degC, this will differ from cpu to cpu this cost me over £250 when new looking for £60 posted thanks EDIT: thought there was something missing:) my reservoir its a big thing lol picks to follow, this is probably capable of cooling a reasonable spec pc on its own:d the acrylic disc is 7cm diameter and its 28cm long all that for £60 bargain;) Link to comment Share on other sites More sharing options...
TurboBrett Posted July 22, 2008 Author Share Posted July 22, 2008 i can see many fish...but none are biting:( Link to comment Share on other sites More sharing options...
