If money were no object - what would your perfect Supra spec be?
Pete
  • Replies 82
Posted Images
  • 10 months later...
Most of my current spec is perfect for me, I would add the following parts in red:
ENGINE
Garrett GT3582R/GT35R (.82 AR T04 Flanged Inlet, 3" Flanged Discharge)
Boost Logic T4 Turbo Blanket
HKS Manifold
HKS Racing Series Wastegate (50mm, 0.9-1.3kg/cm²)
K&N 4" Air Intake
HKS R-Type Front Mounted Intercooler
HKS Racing Blow-Off Valve Type II
HKS Cams in264
HKS Cams ex264
HKS Adjustable Cam Gears
Chris Wilson Tuned Head
HKS S35i Super Fire Spark Plugs
HKS Super Turbo Oil
TRD Oil Filter
EXHAUST
GReddy PE Ti-R Exhaust
HKS Down pipe/mid pipe
COOLING
HKS R-Type Oil Cooler
Power Enterprise Double Row Aluminium Radiator
ARC Titan Radiator Cover
PHR Polished Upper Radiator Pipe
Samco Lower Radiator Pipe
FUELING
WALBRO 341 255 ltr/hr Fuel Pump
HKS Fuel Rail
HKS 680cc Fuel Injectors
HKS Adjustable Fuel Pressure Regulator
ELECTRONICS
HKS F-Con V Pro
HKS F-Con V Pro Harness
HKS F-Con Pressure Sensor
HKS F-Con Temp Sensor
HKS EVC VI Boost Controller
HKS Navigator Pro
RACELOGIC Traction Control
TRANSMISSION & DRIVETRAIN
Standard 6spd Manual
ATS Carbon Clutch
ATS Carbon LSD
SUSPENSION
Öhlins Coilovers
Ikeya Formula Suspension Arms
Carbing Front Strut Brace
Carbing Rear Strut Brace
BRAKES
Endless Front and Rear Brakes
HKS Brake Fluid
WHEELS/TYRES
Rays TE37 Wheels
Advan A050 Tyres
EXTERIOR
TOP SECRET Type III Front Bumper
TOP SECRET Type III Side Skirts
TOP SECRET Type III Rear Spats
Facelift Headlights
Facelift Rear Lights
Facelift Indicators
Clear Side Markers
INTERIOR
TRD Steering Wheel
DEFI 60mm Electronic Boost Gauge
DEFI 60mm Electronic EGT Gauge
DEFI 60mm Fuel Pressure Gauge
DEFI Control Unit
Innovate AFR Gauge
HKS Turbo Timer
GREDDY Dual Pillar Pod
Carbing Roll Cage
Bride Low Max Gias Seats
i love Nic's car, i definately go for his.
Rob
