If money were no object - what would your perfect Supra spec be?
Pete
  • Replies 82
Posted Images
550 - 600 bhp with the trimmings, gauges etc.
Ohlins shocks and relevant springs. All other components would be renewed.
Stock body but perfect, paint would be special though.
If not stock then Stillen front Explosion skirts and Trial or do luck rear with a TRD spoiler. Both versions would have either a do luck or uk bonnet.
Under body would be stripped and anything dodgy renewed cleaned, whole thing waxoyled / protected properly.
Tension set or cage.
The lightest decent wheels I could find in 18" maybe with the Gram Light titanium flame finish.
Exterior engine components would be refurbed and powder coated. Ideally it would be a fully built unit too.
Interior would be custom fabrics and new leather. Dash would be custom built for hi fi and the necessary other displays.
That would do me I think. :)
You're all aiming way to low.
So far for an interview I'm doing I've got:
If budget wasn't an issue? That's a tricky one as there is A LOT of nice kit out there and plenty of conflicting opinions. Similarly there's a lot of tuner junk out there - even from the big names. I'm sure we could start a bar brawl in 30 seconds with a handful of club members with that question!
Personally I wouldn't be interested in building a drag car, it'd have to be a nice all round street and track car.
I'd like to start out with an official TRD wide body car, I prefer the stock look. However there are only a handful of these factory built ones about. The bonnet would have to go with a Stout carbon fibre one in replacement. This is proper full C/F which is very light, not the cosmetic stuff layed on fibreglass that 99% of carbon bonnets are made of. The standard Supra bonnet is made of aluminium and is very light already - most aftermarket bonnets do not save you much, if any weight.
Volks/Rays wheels are very attractive, light, built to specification and high quality. I'm sure I could find a better bespoke magnesium wheel manufacturer if I looked hard though.
I think Top Secret came out with some particularly nice LED rear lights recently. That'd finalise the cosmetic stuff.
Then it would be over to a suspension specialist like Chris Wilson to sort out some proper custom modifications as simply sticking on some wider wheels on a TRD kit isn't really a proper solution (naughty Toyota!). He sorted out some Nitron custom made triple adjustable race dampers for some R34s recently which sounded good (they should do at £8k a set!)
Suitable upgrades to the rest of the drive train like larger floating disc brakes, TRD diff, carbon prop would naturally follow. Some kind of Titanium exhaust to save weight.
Motec Sport Dash Logger (SDL) with a an Innovate LM2 AFR reader. That'd keep most of the monitoring in check. Only problem is with that is that you'd need to make a custom dash, but hey, money is no object so lets build a custom carbon fibre dash. Who does Aston Martin interiors?
It'd be really great to build an engine with some of those new variable vein turbos, but this is uncharted territory and would require a very good mapper and a proper ECU like the Motec ones to do this properly. You don't need 100's of BHP to have a well sorted and fast Supra - my main concern would be drivability through the whole rev range and reliability.
Basically I'd want a lot of specialised, custom race bits which aren't generally available and cost £££'s.
I'm not a technical genius myself so I can't list you a complete spec of what injectors, main bearings and caps I'd go for. I'd leave that in the hands of an expert.
I'm sure I'm missing a lot out though.
Most of my current spec is perfect for me, I would add the following parts in red:
ENGINE
Garrett GT3582R/GT35R (.82 AR T04 Flanged Inlet, 3" Flanged Discharge)
Boost Logic T4 Turbo Blanket
HKS Manifold
HKS Racing Series Wastegate (50mm, 0.9-1.3kg/cm²)
K&N 4" Air Intake
HKS R-Type Front Mounted Intercooler
HKS Racing Blow-Off Valve Type II
HKS Cams in264
HKS Cams ex264
HKS Adjustable Cam Gears
Chris Wilson Tuned Head
HKS S35i Super Fire Spark Plugs
HKS Super Turbo Oil
TRD Oil Filter
EXHAUST
GReddy PE Ti-R Exhaust
HKS Down pipe/mid pipe
COOLING
HKS R-Type Oil Cooler
Power Enterprise Double Row Aluminium Radiator
ARC Titan Radiator Cover
PHR Polished Upper Radiator Pipe
Samco Lower Radiator Pipe
FUELING
WALBRO 341 255 ltr/hr Fuel Pump
HKS Fuel Rail
HKS 680cc Fuel Injectors
HKS Adjustable Fuel Pressure Regulator
ELECTRONICS
HKS F-Con V Pro
HKS F-Con V Pro Harness
HKS F-Con Pressure Sensor
HKS F-Con Temp Sensor
HKS EVC VI Boost Controller
HKS Navigator Pro
RACELOGIC Traction Control
TRANSMISSION & DRIVETRAIN
Standard 6spd Manual
ATS Carbon Clutch
ATS Carbon LSD
SUSPENSION
Öhlins Coilovers
Ikeya Formula Suspension Arms
Carbing Front Strut Brace
Carbing Rear Strut Brace
BRAKES
Endless Front and Rear Brakes
HKS Brake Fluid
WHEELS/TYRES
Rays TE37 Wheels
Advan A050 Tyres
EXTERIOR
TOP SECRET Type III Front Bumper
TOP SECRET Type III Side Skirts
TOP SECRET Type III Rear Spats
Facelift Headlights
Facelift Rear Lights
Facelift Indicators
Clear Side Markers
INTERIOR
TRD Steering Wheel
DEFI 60mm Electronic Boost Gauge
DEFI 60mm Electronic EGT Gauge
DEFI 60mm Fuel Pressure Gauge
DEFI Control Unit
Innovate AFR Gauge
HKS Turbo Timer
GREDDY Dual Pillar Pod
Carbing Roll Cage
Bride Low Max Gias Seats
Dream so far.... :)
3.4L stroker kit
Usual raid on HKS catalogue for uprated items- pistons, intercooler etc
HKS Titanium Exhaust
(leave rest of engine stuff to those in know!)
Carbon fibre propshaft
Best fastest twin turbos for 600bhp
MoTec ECU
Tein Monoflex + EDFC
Greddy 8pots brakes
RLTC
This bodykit(not rear wing) in carbon fibre
These alloys
Full carbon bodyshell + carbon fibre wheels.
Carbon fibre cockpit.
Carbon fibre recaro seat
Lexan windows + screens.
Roll cage
Stock engine with VNT turbo controlled by motec ECU
Brembo 6 pot monoblock calipers front with 4 pot rears.
Custom race spec dampers
Ikeya control arms
I'd import a JGTC Supra.
Id import the youngest, lowest mileage and standardest (:blink:) six speed TT in Gunmetal I could find.
Id get my current one fitted with a Lexus V8 TT conversion, re-sprayed dark graphite, pay CW vast amounts of money to try and get the suspension to work properly with the V8 lump in the front.
I'd buy a scruffy TT and make it into a six wheeled pick up...remove the rear hatch, extend the rear chassis for the additional axle etc.
Id get a Supra TT trike made to my own design, possibly with Jag rear suspension and axle.
I'd buy an LFA.
I'd buy the club a track day Supra and sponsor the build.
