Fitting UK 2nd decat to a j spec TT
hadyn
Hi all,
Is it possible to fit a uk spec 2nd decat to a j-spec? AFAIK they're both exactly the same shape, you just need to plug the hole on the uk spec 2nd decat for the 02 sensor which isnt there on a j-spec?
Am I correct? I think so :)
Also, I presume fitting the 2nd decat is pretty easy?
WD40 on the bolts, then should be no probs to take off with the car jacked up? Certainly not the nightmare that taking the 1st cat off could turn into with snapped bolts/lack of accessibility etc...
