Facelift grill bar fitment
Guigsy
Hi guys.
I need someone with a facelift car to do me a favour.
Ive got a facelift centre grill bar from Mr t. Sprayed up and ready to fit. I just wondered exactly how it fits in the bumper? There are a couple of holes to attach it into the top and bottom and then 2 holes on each end. I just wondered how it was actualy fitted into the bumper? i dont want to drill holes and get it wrong :p
I can start you off, and hopefully someone can add to or correct me.
The facelift grill bar has two location bosses at each end, the central upright has two fixing holes at the top, and one at the bottom.
The bosses at each end of the bar locate in two holes already there on a facelift bumper....dont know if the pre-facelifts have these or not. From memory, the bosses just pop into and locate in these holes...I cant remember if there were bolts fitted, sorry.
The central upright uses the fixings on the existing trim....the lower, single fixing is the central captive bolt for the lower black lining strip along the bumper inlet hole...the upper two fixings use the two central pull-out studs for the alloy stiffener that runs across the top edge of the bumper inlet hole...again, I dont know if these trim fixings are the same on the non-facelift.
Edited by Ewen
Edited since seeing the photos (see edit history)
Hi guys.
Can i be rude and ask how much you payed for the grill bar as mine has it missing,cheers
Thats just how i attached it. My car is a uk spec and i dont have any holes in the bumper to slot the end bits into so i pulled off the little things on the end and it seems to hold just right.
:D
Cheers
:D
Cheers
Thanks mate will have to get myself off to toyota hehe
  • 5 years later...
