Mike_Mac Posted July 19, 2008 Share Posted July 19, 2008 I need to make room and clear some of the bits that are clogging my house up. For Sale is: 1. SpeedM8 speedo converter. Works in a similar fashion to the Thor unit. Cost me £65. Comes with instructions - £20[ - SOLD 2. J-Spec Speedo with UK dial face. Ideal to fit in place of yours for a fully UK spec look. - £15. - SOLD 3. UK spec instrument cluster. Comes with Rev counter, black plastic surround and perspex dial cover but no speedo dial and the fuel gauge has no dial face or needles. worth more than a fiver just considering the bulbs that come with it. - £5. - SOLD 4. Folding mirror switch. - £5. 5. Mirror adjustment switch. - £5. 6. Lower Dash Panel (under the steering wheel) with hole for fog light switch. - £2. 7. Rear boot blind restrainer x 2. - £2. All items do not include postage. Once I have your address I'll let you know exactly how much it is and add that to the total. If using Paypal then add 4% on top of that as well. Please note I'll be away and uncontactable from Monday through 'till ~ 1st Aug, so I may be a bit late in getting back to you. Link to comment Share on other sites More sharing options...
jlgee80 Posted July 19, 2008 Share Posted July 19, 2008 Hi mate. Do you have any pics of the jspec speedo with the uk dial face? I just cant picture it. Definately Interested. Jason. Link to comment Share on other sites More sharing options...
Mike_Mac Posted July 19, 2008 Author Share Posted July 19, 2008 See below. You'll still need to have a converter for it to be accurate, but it gives the car a UK look and allows you to get rid of the 112 mph faces that some companies fit on the cheap without having to remove your speedo needle. This one's needle has been properly re-attached and is accurate. I wa running it in my car for the last year until I managed to get hold of a complete UK speedo, which already has a Uk face (funnily enough!) I paid around £30 delivered for that UK face and more for the complete UK speedo I replaced it with. Link to comment Share on other sites More sharing options...
razza Posted September 9, 2008 Share Posted September 9, 2008 7. Rear boot blind restrainer x 2. - £2. Is this the clips behind the seats or the ones that attach to the boot with elastic on them? Link to comment Share on other sites More sharing options...
lendusz Posted September 9, 2008 Share Posted September 9, 2008 Hello Mate, I'd be interested in the speedo converter. Cheers, Pete Link to comment Share on other sites More sharing options...
Mike_Mac Posted September 18, 2008 Author Share Posted September 18, 2008 Sorry it took so long to get back with answers - I didn't get an Email telling me I had replies. Is this the clips behind the seats or the ones that attach to the boot with elastic on them? It's the parts that have the elastic strip to hook onto the blind. They are attached to the boot itself. Hello Mate, I'd be interested in the speedo converter. Cheers, Pete If you're still interested then it's still available? Link to comment Share on other sites More sharing options...
hoff Posted September 18, 2008 Share Posted September 18, 2008 Is the speedo convertor an easy to fit job, or does it invove getting into the wiring loom like some? If there is no loom work involved I'll have 2nd dibs on it for sure:) Link to comment Share on other sites More sharing options...
Mike_Mac Posted September 19, 2008 Author Share Posted September 19, 2008 Is the speedo convertor an easy to fit job, or does it invove getting into the wiring loom like some? If there is no loom work involved I'll have 2nd dibs on it for sure:) Sorry - it's wired into the loom behind the speedo exactly the same as a Thor unit. It's not an epic to fit though so long as you know roughly how to use a soldering iron. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted September 19, 2008 Share Posted September 19, 2008 How easy is it to fix the speedo in place? Is it just a simple case of taking the old one out and 'bolting' a new one in? If so I am deff interested as mine's been converted but will only read to 112 Link to comment Share on other sites More sharing options...
Missile Posted September 19, 2008 Share Posted September 19, 2008 Where does the folding mirror switch go ? Does it go down by the gear stick ? I don't have folding windows, But want to cover a hole i have. Link to comment Share on other sites More sharing options...
Mike_Mac Posted September 19, 2008 Author Share Posted September 19, 2008 How easy is it to fix the speedo in place? Is it just a simple case of taking the old one out and 'bolting' a new one in? If so I am deff interested as mine's been converted but will only read to 112 The speedo is simple to get out - Once you've removed the cluster it's just a case of unscrewing some obvious screws at the back and then slotting the new one into place. I've already had interest in the speedo though, but I'll give you first dibbs if it isn't taken. Where does the folding mirror switch go ? Does it go down by the gear stick ? I don't have folding windows, But want to cover a hole i have. It's designed to fit in the RHS dash panel, so I don't think it'lll fit without some work Link to comment Share on other sites More sharing options...
Missile Posted September 19, 2008 Share Posted September 19, 2008 When you say RHS does that mean right hand drive ? Or did you mean left hand drive ??? Confused mate... Link to comment Share on other sites More sharing options...
Mike_Mac Posted September 19, 2008 Author Share Posted September 19, 2008 When you say RHS does that mean right hand drive ? Or did you mean left hand drive ??? Confused mate...Right Hand Side, as in from the steering wheel on the dash (just below the air vent). Link to comment Share on other sites More sharing options...
Missile Posted September 19, 2008 Share Posted September 19, 2008 I got you. So not in the centre then. Thanks very much... Link to comment Share on other sites More sharing options...
Mike_Mac Posted September 23, 2008 Author Share Posted September 23, 2008 Items that have sold have now been updated. Link to comment Share on other sites More sharing options...
