650CC injectors
StuartW
SOLD£250
650 prescision 550HP capable.
Done less than 500miles.
These Cost £450 new when bought less than a year ago
£285 delivered will do for a N/A-T,BPU++, TT/Big single but the TT will need aftermarket rail, you can get good copies from eBay for £59.99 http://cgi.ebay.co.uk/Toyota-Fuel-Rail-JZA80-MKIV-Supra-2JZ-GTE-TOP-FEED_W0QQitemZ150318259037QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item150318259037&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
for an N/A-t they are a direct fit.
High impedance so no resistors needed.
Clips also available for extra £25 or just use speaker spade crimpits
  • 2 months later...
  • 1 month later...
Have you got a pic of the injectors installed? I would of thought 650cc is a bit over the top for 300 ish hp?
These dont even need a resistor pack :D
I had these when my 440's from a mk3 didnt supply enough fuel @ 1 Bar and i melted the pistons in my first N/A-T. Better off safer than sorry. They are great quality and have a 4 jet spray pattern.
  • 1 month later...
what rail is needed for precision injectors ?
This one on eBay will work fine, in stock in the UK £59.99 its an exact HKS copy and looks Bling! This will flow much better than a std rail and will accept an FPR much easier ;)
I can guarantee this will 100% fit and the Aluminium collars etc will allow my Injectors to fit perfectly.
The HKS equivalent is over £200!
  • 2 weeks later...
  • 2 weeks later...
does any one kn ow if they will fit a 1jz will be looking at an after market rail for it
YES they will fit straight in!
Originally i had these to drop in on my MKiv N/A-T with standard fuel rail, That was after i had used mk3 440cc from a single turbo 1JZ.
SO they should fit 100% mate. and i am pretty sure you wont even need a resistor pack on the 1JZ.
Any news on the tanks mate..
Stuart
  • 2 weeks later...
  • 3 weeks later...
  • 1 month later...
These had sold to a member but upon arrival they appear to be Siemens injectors NOT Prescision! I was sold them as Prescision, I dont really see what difference it makes as they are top quality as the flow testing confirms...
Anyways
BACK UP FOR SALE :rolleyes:
remember i was talking to you about a rail for the ''precision'' injectors and you said the hks copy rails will work fine etc , i bought one then as i have precision injectors here in the box and they wouldnt fit the rail :(
Precision will only fit US brand rails like Titan, SP, boost logic etc
