Hi guys i need help badly!!!
Guest The_Scorpion
Guest The_Scorpion
hi,
i need some help here with several things,
i have replaced my original dial facia's with stainless steel ones but in doing so i broke my fuel meter!
the pionter is pressed on a steel needle but when i tried to remove the pionter the steel needle broke so i need to replace it!
does anyone know a crashed or donor supra with RHD 93 model dials in it so that i can replace mine????
(and maybe with an cruise control stalk in it aswell?)
then i replaced my original wheel with the cruise control and airbag for an momo steering wheel but i cant get my horn working!
i took of the original wheel and took out the jellow type ring from the steering collum.
then i replaced the cruise control stalk in the steering collum and snapped of the plugs from the steering collum and the cruise control stalk then i started to reconnect the wires by color.
now if the cruise control works i dont know realy since the button wont stay pushed in anymore so i think i need to replace it but the how the hell do i need to connect the horn to make it work??
i hope anyone can give me some advice and help here!!?????????
Advice.... don't do anymore work on your own, especially when it comes to important stuff.
As for the items you are looking for if you go to the "Wanted" section and post the things you are looking for people will reply with what they have. Most traders and breakers look in there daily.
