Auto gearbox how to change the oil
hemmjonny
FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
http://mkivsupra.net/vbb/showthread.php?t=56684
Soarer -- but basically the same 'box (likely to be different part numbers, obviously).
http://www.soarerworld.com/forum/showthread.php?t=286
(Youll have to sift through the "banter" :))
Full flush
http://www.amsoil.com/storefront/atf.aspx
ATF and Transmission Filter Change Procedures (45k PDF)
Edited by garethr (see edit history)
